My mcp2515 can module could not send or receive datas on the Jetson Nano
Hi, please help me to send and recv data over mcp2515 module on Jetson Nano
Here are my steps:
  1. write system image into microSD card (Jetpack 4.5, download from https://developer.nvidia.com/jetson-nano-sd-card-image)
  2. Connect mcp2515 module to SPI_1
    INT – pin 31
    MOSI – pin 19
    MISO – pin 21
    SCK – pin 23
    CS – pin 24
    GND – pin 6
    VCC – pin 1(3.3V) or pin (2 5.0V)
    (I have to mcp2515 can module, one oscillator is 8MHz, another is 11.0592MHz, I use the 11.0592MHz controller to descpribe the problem follow)
  3. Use jetson-IO tool to select mcp device(/opt/nvidia/jetson-io/jetson-io.py–>select “MCP251x CAN Controller”)
  4. reboot
  5. generate dts file from “kernel_tegra210-p3448-0000-p3449-0000-b00-mcp251x-can-controller.dtb”
  6. modify dts file:
    a: modify frequency for can_clock
    clocks {
     can_clock {
     	phandle = <0x136>;
     	linux,phandle = <0x136>;
     	clock-accuracy = <0x64>;
     	clock-frequency = <0xA8C000>; // or double <0x1518000>
     	#clock-cells = <0x0>;
     	compatible = "fixed-clock";
    b: modify spi@7000d400 part(spi-max-frequency):
    spi@0 {
    interrupts = <0xc8 0x1>;
    interrupt-parent = <0x5b>;
    clocks = <0x136>;
    nvidia,rx-clk-tap-delay = <0x7>;
    nvidia,enable-hw-based-cs;
    compatible = “microchip,mcp2515”;
    reg = <0x0>;
    spi-max-frequency = <0x546000>; // or double <0xA8C000>
     	controller-data {
     		nvidia,tx-clk-tap-delay = <0x0>;
     		nvidia,cs-hold-clk-count = <0x1e>;
     		nvidia,cs-setup-clk-count = <0x1e>;
     		nvidia,rx-clk-tap-delay = <0x1f>;
  7. generate to “kernel_tegra210-p3448-0000-p3449-0000-b00-mcp251x-can-controller.dtb” for my dts file
  8. reboot
  9. load can driver:
    modprobe can
    modprobe can-raw
    modprobe can-bcm
    modprobe can-gw
    modprobe can-dev
    modprobe mttcan
  10. set up can0:
    ip link set can0 type can bitrate 100000
    ip link set up can0
  11. use candump and cansend to test on can0
My operation screenshort:
My DTS files:
extlinux.conf (1.2 KB) mcp-11.0592m.dts (329.4 KB) mcp-11.0592m_double.dts (329.4 KB)
My mcp2515 can module link:
https://wiki.diustou.com/MCP2515_CAN总线模块
another mcp2515 can module link(it work fine on raspberrypi):
https://wiki.diustou.com/RS485_CAN_HAT
Can anyone fix this?
Check this : Jetson nano and mcp2515 can module
