Jetson Nano MCP 2515 + MCP2551 CAN Communication
Hi all,
i am new to jetson nano. i am familiar to rpi. now i have an urgent requirement to interface Jetson Nano using CAN bus Spi MCP2515 and MCP 2551. Please help me out with a detailed tutorial of how to work with it. on the other hand i have stm board with can bus working fine.
thanks and regards
Please refer to How enabling MCP251x (MCP2515) on the Jetson Nano (SPI CAN)?
Hi… I have been struggling for the same work from past few days. I have been following the link provided on previous link. Also, some more link i went thoroughly includes
Topics tagged can-bus
but somehow the information is sparse and not clear for “latest version” of Jetpack.
My questions are 1) Is pinmux changes are required if we are using jetpack-io.py file?
2) When using jetpack-io.py, DTB file is generated. how to generate .dtbo file from that? and how to convert it into back .dts file?
I would really appreciate if correct steps can be provided on Jetson nano (b00).
Hi poonam.jangid,
Please help to open a new topic. Thanks
Hi All,
I connected one mcp module(8Mhz) and another microcontroller board with mcp2551 transceiver. In the dtb i used the can clock frequency same as crystal used and i was able to receive the data using can dump. However one situation is that can send will only work after the 2 commands
  1. cansend can0 123#FF
  2. sudo ip link set can0 down
    Only after these 2 steps the data will be received on the microcontroller board. My requirement is i want to receive the data at controller without executing the step number 2(right after step 1).
please suggest possible solutions.
