Below is jetson-io add for the 40-pin, you can check the pin 19,21,23,24,26 was configure as SPI function.
pinmux@700008d4 {
compatible = "nvidia,tegra210-pinmux";
reg = <0x0 0x700008d4 0x0 0x2a5 0x0 0x70003000 0x0 0x294>;
#gpio-range-cells = <0x3>;
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <0x136>;
pinctrl-1 = <0x3e>;
pinctrl-2 = <0x3f>;
linux,phandle = <0x40>;
phandle = <0x40>;
header-40pin-pinmux {
phandle = <0x136>;
linux,phandle = <0x136>;
pin37 {
nvidia,enable-input = <0x1>;
nvidia,tristate = <0x0>;
nvidia,pull = <0x1>;
nvidia,pins = "spi2_mosi_pb4";
nvidia,function = "spi2";
pin28 {
nvidia,io-high-voltage = <0x1>;
nvidia,pull = <0x0>;
nvidia,pins = "gen1_i2c_scl_pj1";
nvidia,function = "i2c1";
pin27 {
nvidia,pins = "gen1_i2c_sda_pj0";
pin26 {
nvidia,pull = <0x2>;
nvidia,pins = "spi1_cs1_pc4";
nvidia,function = "spi1";
pin24 {
nvidia,pins = "spi1_cs0_pc3";
pin23 {
nvidia,pins = "spi1_sck_pc2";
pin22 {
nvidia,pins = "spi2_miso_pb5";
pin21 {
nvidia,pins = "spi1_miso_pc1";
pin19 {
nvidia,pins = "spi1_mosi_pc0";
pin18 {
nvidia,pins = "spi2_cs0_pb7";
pin16 {
nvidia,pins = "spi2_cs1_pdd0";
pin13 {
nvidia,pins = "spi2_sck_pb6";
pin10 {
nvidia,tristate = <0x1>;
nvidia,pins = "uart2_rx_pg1";
nvidia,function = "uartb";
pin8 {
nvidia,enable-input = <0x0>;
nvidia,pins = "uart2_tx_pg0";
pin5 {
nvidia,pins = "gen2_i2c_scl_pj2";
nvidia,function = "i2c2";
pin3 {
nvidia,pins = "gen2_i2c_sda_pj3";
