What is format of output file as given by 10_camera_recording ? Is it h264 elementary stream ? Is there is a way to view this output by external mp4 or mkv players ? I have this situation where I am recording using mechanisms given (v4l2 based) in this example - but would like to play output in external players ? What converters should I use ?
THanks for helping out. Would it be possible to parse output.h264 (i.e. output generated by v4l2 based NvVideoEncoder) and find at what frame rate the elementary bitstream is getting created ? Any parsers out there for this ? Can ffmpeg find out ?
Hi DaneLLL
Thanks. Can you please give the ffmpeg command to play h264 bitstream encoded by NvVideoEncoder ? I am unable to figure out from ‘man ffmepg’ or from ffmpeg command lines as found on web.
