I’m using L4T 32.3.1 on a Jetson Nano based product and I am interested in supporting encoding of extended color range data to H.264 and H.265 using the MMAPI. I have modified our own product code to support this but I noticed that the encoder does not seem to support any of the _ER formats (e.g. NvBufferColorFormat_YUV420_ER).
Thinking it was probably a mistake I made, I went back and flashed the stock Ubuntu distro and tested the video_encode sample as well, with the --enable-extcolorfmt flag. This also fails in the same way as my own code. There are some messages printed to the console when this happens (these are from running the video_encode sample):
NvMMLiteVideoEncDoWork:NvMSEncConvertSurfaceFormat failed
VENC: NvMMLiteVideoEncDoWork: 4231: BlockSide error 0x4
NvVideoEnc: BlockError
NvVideoEncTransferOutputBufferToBlock: DoWork failed line# 667
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=678
[ERROR] (NvV4l2ElementPlane.cpp:178) <enc0> Capture Plane:Error while DQing buffer: Invalid argument
Error while dequeing buffer from output plane
[ERROR] (NvV4l2ElementPlane.cpp:256) <enc0> Output Plane:Error while Qing buffer: Invalid argument
Error while queueing buffer at output plane
If I run the video_encode sample without the --enable-extcolorfmt flag it does work as expected.
For reference, I have a different TX1-based product which originally used L4T 28.2. I updated this product to 28.3.2 and added support for extended color range formats, and everything is working on this product.
Any ideas or help with this are greatly appreciated.
I’m happy to provide any other details on the system. If this works on your setup, I will be happy to know it is supposed to work and something must be wrong on my end.
I have one more question related to this. Will the next release support the _709_ER variants of the NvBufferColorFormat enum (e.g. NvBufferColorFormat_YUV420_709_ER) as well? I am hoping this will be supported.
Thanks for the information. I was more wondering if my own application used in my product would be able to support those values, as I will be encoding HD video in BT.709 format. This does seem to be supported on L4T 28.3.2 which I use in another product. It won’t matter to me if 01_video_encode supports BT.709 or not, but it would be nice if the encoder supports it in general.
For anybody else visiting this post later, I can confirm that NvBufferColorFormat_YUV420_ER, NvBufferColorFormat_YUV420_709_ER are both working with the underlying encoder software in rev 32.4.2.
Hi @cjwti
Thanks for the confirmation. One issue is color space is not put in VUI to distinguish BT601 and BT709. We shall have this supported in next release.
Thanks! That’s a good point, and I’m glad to hear it will be added in a future release. If you guys are considering adding support for anything else to the VUI information, I would like to vote for adding aspect ratio support. I have some code to transform the VUI for H.264/H.265 because I need to insert all this extra data and the older L4T release that I started from didn’t support it.
