Hi, we use the same NvJPEGEncoder to encode images with different sizes and format, other format will be transformed to YUV420 on necessary, the output is incorrect sometimes.
Here is a sample code to reproduce this problem:
#include "NvJpegEncoder.h"
#include "nvbufsurface.h"
#include "nvbufsurftransform.h"
#include <assert.h>
#include <stdlib.h>
#include <memory>
#include <iostream>
#include <fstream>
NvBufSurface *allocate(int width, int height, NvBufSurfaceColorFormat format) {
NvBufSurfaceAllocateParams create_params;
memset(&create_params, 0, sizeof(create_params));
create_params.params.width = width;
create_params.params.height = height;
create_params.params.memType = NVBUF_MEM_SURFACE_ARRAY;
create_params.params.layout = NVBUF_LAYOUT_PITCH;
create_params.params.colorFormat = format;
create_params.memtag = NvBufSurfaceTag_VIDEO_CONVERT;
NvBufSurface *surf = nullptr;
int ret = NvBufSurfaceAllocate(&surf, 1, &create_params);
assert(ret == 0);
surf->numFilled = 1;
return surf;
void destroy(NvBufSurface *surf) {
int ret = NvBufSurfaceDestroy(surf);
assert(ret == 0);
void transform(NvBufSurface *src, NvBufSurface *dst) {
NvBufSurfTransformParams transform_params;
memset(&transform_params, 0, sizeof(transform_params));
transform_params.transform_flag = NVBUFSURF_TRANSFORM_FILTER;
transform_params.transform_filter = NvBufSurfTransformInter_Nearest;
int ret = NvBufSurfTransform(src, dst, &transform_params);
assert(ret == 0);
void encode(std::shared_ptr<NvJPEGEncoder> enc, NvBufSurface *surf, std::string name) {
int width = surf->surfaceList[0].width;
int height = surf->surfaceList[0].height;
unsigned long buf_size = width * height * 3 / 2;
unsigned char *buf = new unsigned char[buf_size];
NvBufSurface *tmp;
if (surf->surfaceList[0].colorFormat == NVBUF_COLOR_FORMAT_YUV420) {
tmp = surf;
} else {
tmp = allocate(width, height, NVBUF_COLOR_FORMAT_YUV420);
transform(surf, tmp);
int fd = tmp->surfaceList[0].bufferDesc;
int ret = enc->encodeFromFd(fd, JCS_YCbCr, &buf, buf_size, 90);
assert(ret == 0);
if (tmp != surf) {
destroy(tmp);
std::ofstream out("output_ " + name + ".jpg");
out.write((char *) buf, buf_size);
delete[] buf;
int main(int argc, char *argv[]) {
auto enc = std::shared_ptr<NvJPEGEncoder>(NvJPEGEncoder::createJPEGEncoder("enc"));
NvBufSurface *yuv420 = allocate(1920, 1080, NVBUF_COLOR_FORMAT_YUV420);
int ret;
ret = NvBufSurfaceMemSet(yuv420, 0, 0, 128);
assert(ret == 0);
ret = NvBufSurfaceMemSet(yuv420, 0, 1, 64);
assert(ret == 0);
ret = NvBufSurfaceMemSet(yuv420, 0, 2, 192);
assert(ret == 0);
encode(enc, yuv420, "yuv420");
NvBufSurface *nv12s = allocate(1920 / 2, 1080 / 2, NVBUF_COLOR_FORMAT_NV12);
transform(yuv420, nv12s);
encode(enc, nv12s, "nv12s");
destroy(nv12s);
NvBufSurface *nv12 = allocate(1920, 1080, NVBUF_COLOR_FORMAT_NV12);
transform(yuv420, nv12);
encode(enc, nv12, "nv12");
destroy(nv12);
return 0;
To compile this sample:
g++ -std=c++11 -I/usr/src/jetson_multimedia_api/include \
-I/usr/src/jetson_multimedia_api/include/libjpeg-8b \
main.cc \
/usr/src/jetson_multimedia_api/samples/common/classes/NvBuffer.cpp \
/usr/src/jetson_multimedia_api/samples/common/classes/NvElement.cpp \
/usr/src/jetson_multimedia_api/samples/common/classes/NvElementProfiler.cpp \
/usr/src/jetson_multimedia_api/samples/common/classes/NvLogging.cpp \
/usr/src/jetson_multimedia_api/samples/common/classes/NvJpegEncoder.cpp \
-L/usr/lib/aarch64-linux-gnu/tegra \
-lnvbufsurface -lnvbufsurftransform -lnvjpeg -o main
The incorrect image is output_nv12.jpg:
Which is expected to be pure orange.
FYI: if we create a new encoder for each image, everything is just fine.
