Hi all !
Could anyone suggest the best way to encode NV12 images with following params:
width=1920, height=1080, pitch=2048
to JPEG ?
Now I am trying to do this with nvJPEG and after four days I still have no success and getiing distorted image:
and no any errors during conversion.
The code is following:
#include <fstream>
#include <filesystem>
#include <nvjpeg.h>
#include "nvidia-support/screenshoter.h"
namespace nvt {
namespace nvidia {
screenshoter::screenshoter(transcoding_config& config){
NVTLOGINFO("screenshoter::screenshoter():config: enabled={}, save={}, directory={}, width={}, quality={}, frequency={}", config.screenshots.enabled,
config.screenshots.save,
config.screenshots.directory,
config.screenshots.width,
config.screenshots.quality,
config.screenshots.frequency);
// DEBUG !
_config = config;
enebled = config.screenshots.enabled;
if(!enebled)
return;
save = config.screenshots.save;
if(save)
directory = config.screenshots.directory;
std::filesystem::create_directories(directory);
if(directory.back() != '/')
directory += "/";
screenshot_width = config.screenshots.width;
quality = config.screenshots.quality;
frequency = config.screenshots.frequency;
cudaGetDeviceProperties(&props, config.gpu);
NVTLOGINFO("screenshoter::screenshoter(): Using GPU {} ({}, {} SMs, {} th/SM max, CC {}.{}, ECC {})",
config.gpu, props.name, props.multiProcessorCount,
props.maxThreadsPerMultiProcessor, props.major, props.minor,
props.ECCEnabled ? "on" : "off");
status = nvjpegCreateSimple(&nvjpeg_handle);
NVTLOGINFO("screenshoter::screenshoter():nvjpegCreate({})", status);
status = nvjpegJpegStateCreate(nvjpeg_handle, &jpeg_state);
NVTLOGINFO("screenshoter::screenshoter():nvjpegJpegStateCreate({})", status);
status = nvjpegEncoderStateCreate(nvjpeg_handle, &encoder_state, NULL);
NVTLOGINFO("screenshoter::screenshoter():nvjpegEncoderStateCreate({})", status);
status = nvjpegEncoderParamsCreate(nvjpeg_handle, &encode_params, NULL);
NVTLOGINFO("screenshoter::screenshoter():nvjpegEncoderParamsCreate({})", status);
status = nvjpegEncoderParamsSetQuality(encode_params, quality, NULL);
NVTLOGINFO("screenshoter::screenshoter():nvjpegEncoderParamsSetQuality({})", status);
//status = nvjpegEncoderParamsSetOptimizedHuffman(encode_params, 0, NULL);
//NVTLOGINFO("screenshoter::screenshoter():nvjpegEncoderParamsSetOptimizedHuffman({})", status);
status = nvjpegEncoderParamsSetSamplingFactors(encode_params, NVJPEG_CSS_444, NULL);
NVTLOGINFO("screenshoter::screenshoter():nvjpegEncoderParamsSetSamplingFactors({})", status);
index = 0;
screenshoter::~screenshoter(){
NVTLOGINFO("screenshoter::~screenshoter()");
if(!enebled)
return;
nvjpegEncoderParamsDestroy(encode_params);
nvjpegEncoderStateDestroy(encoder_state);
nvjpegJpegStateDestroy(jpeg_state);
nvjpegDestroy(nvjpeg_handle);
bool screenshoter::encode(unsigned char* cuda_buffer,
const size_t frame_width,
const size_t frame_height,
const size_t frame_pitch){
NVTLOGINFO("screenshoter::encode(): frame_width={}, frame_height={}, frame_pitch={}", frame_width, frame_height, frame_pitch);
screenshot_height = (double)screenshot_width * (double)frame_height / (double)frame_width;
cudaDeviceSynchronize();
size_t buffer_size = frame_width * frame_height * NVJPEG_MAX_COMPONENT;
unsigned char* rgb_buffer;
cudaError_t cuda_error = cudaMalloc((void**)&rgb_buffer, buffer_size);
NVTLOGINFO("screenshoter::encode(): cudaMalloc({})", cuda_error);
const Npp8u *const pSrc[2] = {cuda_buffer, cuda_buffer + frame_width * frame_height};
NppiSize oSizeROI;
oSizeROI.width = frame_width;
oSizeROI.height = frame_height;
NppStatus npp_status = nppiNV12ToRGB_8u_P2C3R (pSrc, frame_pitch, (Npp8u*)rgb_buffer, frame_width * 3, oSizeROI);
NVTLOGINFO("screenshoter::encode(): nppiNV12ToRGB_8u_P2C3R({})", npp_status);
nvjpegImage_t frame =
rgb_buffer,
rgb_buffer + frame_width * frame_height,
rgb_buffer + frame_width * frame_height * 2,
rgb_buffer + frame_width * frame_height * 3
(unsigned int)frame_width,
nvjpegStatus_t status = nvjpegEncodeImage(nvjpeg_handle,
encoder_state,
encode_params,
&frame,
NVJPEG_INPUT_RGB,
screenshot_width,
screenshot_height,
NULL);
NVTLOGINFO("screenshoter::encode(): nvjpegEncodeImage({})", status);
std::vector<unsigned char> screenshot;
size_t length = 0;
status = nvjpegEncodeRetrieveBitstream(nvjpeg_handle,
encoder_state,
NULL,
&length,
NULL);
NVTLOGINFO("screenshoter::encode(): nvjpegEncodeRetrieveBitstream({}):length={}", status, length);
screenshot.resize(length);
encoder_state,
screenshot.data(),
&length,
NULL);
NVTLOGINFO("screenshoter::encode(): nvjpegEncodeRetrieveBitstream({})", status);
if(save)
std::string file_name("screenshot_");
file_name += std::to_string(++index);
file_name += ".jpeg";
file_name = directory + file_name;
std::ofstream output_file(file_name, std::ios::out | std::ios::binary);
output_file.write((const char*)screenshot.data(), length);
output_file.close();
cudaFree(rgb_buffer);
return true;
} /* namespace nvidia */
} /* namespace nvt */
I tried to pack NV12 frame to nvjpegImage_t structure directly and use
nvjpegStatus_t status = nvjpegEncodeYUV(nvjpeg_handle,
encoder_state,
encode_params,
&frame,
NVJPEG_CSS_420, // For NV12 encoded frame
screenshot_width,
screenshot_height,
NULL);
but in this case result is following:
and I have no idea how to pack it into nvjpegImage_t correctly. I suppose that the reason is pitch=2048 while width=1920, but don know to solve this problem.
Any help please !
