I`m considering using Jetson Nano for my future project. Finally one affordable computer from Nvidia that looks very promising.
However first I would like to know if Jetson Nano is capable of encoding 1080p30fps video from USB camera (in Raw, YUV or MJPEG format) to H.264 or H.265 for real-time streaming?
My project:
I need video feed from my drones USB camera to be streamed in real-time over internet (web browser based interface for operator).
I need as little latency as possible, below 200 ms or so. Encoding should be done by GPU or hardware encoder (if Jetson Nano has one) because I don`t want to put that extra load on CPU.
Is that feasible with Jetson Nano?
I have no previous experience with Nvidia single-board computers.
Hi syvva, yes this is possible, Jetson Nano has a hardware video encoder and decoder. Recommend looking at the L4T Accelerated GStreamer User Guide for examples:
Thanks for your asking this question because I have similar query. Have you found solution to your problem? If yes, could your share at least a snippet of your code of h.265 encoding!
Good to know that I`m not the only one wanting to do this.
Unfortunately I have not started writing code yet because I decided to design custom ESC and a new controller board for my drone. Still developing this hardware.
I wanted to get quick heads up with my question to make sure Jetson Nano is up for the task.
Please let me know if you find the solution before I do.
NB! I found lots of very informative threads in these forums. Some are explaining video encoding very well.
@alicanavar
You’d better create a new topic, you would get more visibility than within an old solved topic.
Also be sure to clearly explain what you want to acheive, how you’re trying to do (code or commands) and what fails (error messages) for better advice.
