Encrypted ssd nvme on Jetson Orin NX
Good day everyone!
I’m trying to enable full disk encryption on a Jetson Orin NX with an NVMe SSD connected to the host via USB.
The host is running Ubuntu 22.04 with JetPack 36.4.4.
Without encryption, the image is created, flashed, and boots up normally.
With encryption, it hangs and never reaches the passphrase prompt.
The command used to create the image:
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
  --no-flash \
  --external-device nvme0n1p1 \
  -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml \
  -S 715GiB \
  --external-only \
  --network usb0 \
  jetson-orin-nano-devkit external
The corresponding flashing command:
  -S 715GiB \
  --external-only \
  --network usb0 \
  --flash-only \
Logs are attached.
Any help would be greatly appreciated.
load.log (35.0 KB)
Based on the provided context, I will attempt to provide a comprehensive answer to the question.
The issue you’re facing is that the Jetson Orin NX with an NVMe SSD connected via USB is not booting up with full disk encryption enabled. The command used to create the image and the flashing command are not provided, but I’ll provide general guidance on how to troubleshoot and potentially resolve the issue.
Disk Encryption on Jetson Devices
Jetson devices support disk encryption on internal or external devices, including NVMe SSDs. To enable disk encryption, you need to set ROOTFS_ENC=1 when running the l4t_generate_ota_package.sh script to generate an OTA payload package. You can also specify the key file for disk encryption using the -i option.
Layout of an Encrypted Disk
When disk encryption is enabled, the APP partition is divided into two:
  • The unencrypted APP partition contains the /boot branch of the file system, including the kernel, DTB, and initrd images.
  • A new, encrypted APP_ENC partition contains the rest of the file system.
Troubleshooting Steps
  1. Verify the eks_t234.img file: Make sure that the ${TARGET_BSP}/bootloader/eks_t234.img file contains the same keys as the ones exist in the EKS partition on the device to be updated. To generate the eks_t234.img file, refer to the Tool for EKB Generation in OP-TEE.
  2. Check the board configuration file: Ensure that the board configuration file (e.g., Linux_for_Tegra/p3737-0000-p3701-0000.conf.common) has the correct settings for disk encryption. Specifically, verify that disk_enc_enable=1 and EMMC_CFG points to the correct partition layout file (e.g., flash_l4t_t234_qspi_sdmmc_enc_rfs.xml).
  3. Verify the partition layout: Check the partition layout file (e.g., flash_l4t_t234_qspi_sdmmc_enc_rfs.xml) to ensure that it correctly defines the APP and APP_ENC partitions.
  4. Check the flashing command: Verify that the flashing command is correct and includes the necessary options for disk encryption.
  5. Check the logs: Analyze the logs to identify any errors or issues that may be causing the boot process to hang.
Comparison with Other Jetson Devices
The process for enabling disk encryption on Jetson Orin NX is similar to other Jetson devices, such as Jetson AGX Orin. However, the specific configuration files and partition layouts may differ depending on the device and its configuration.
Additional Tips
  • Ensure that the NVMe SSD is properly connected and configured on the host system.
  • Verify that the Ubuntu 22.04 host system has the necessary packages and dependencies installed for disk encryption.
  • If you’re using a custom kernel or device tree, ensure that they are correctly configured for disk encryption.
By following these troubleshooting steps and verifying the configuration files and partition layouts, you should be able to identify and resolve the issue preventing the Jetson Orin NX from booting up with full disk encryption enabled.
Subject: Issue with Jetson Orin NX Encrypted NVMe — No Passphrase Prompt During Boot
Hi everyone,
Sorry if I didn’t explain it clearly before — I’m trying to get the attention of the support specialists. Over the past month, I’ve read a lot on the topic of disk encryption for Jetson:
All the keys have already been generated, the password/key bindings are configured, and the firmware build and flashing process complete successfully. However, the boot process stops without asking for a passphrase.
The SSD partition itself is definitely encrypted — I verified it by connecting the drive directly to the host.
The flashing is performed using the following command:
–external-device nvme0n1p1 \
-S 715GiB \
–external-only \
–network usb0 \
–flash-only \
I’m attaching the flashing logs.
I would really appreciate any help or suggestions.
Thanks in advance!
load.log (38.4 KB)
flash_1-7_0_20251030-162229.log (109.4 KB)
hello slobodenuksk,
FYI, we’re not supported disk encryption with a prompt for passphrase by default.
please customize it (a prompt for passphrase) by yourself, please see-also Topic 316813.
it’s failed to unlock NVMe according to your latest logs..
[   10.319195] ERROR: fail to unlock the encrypted dev /dev/nvme0n1p2.
[   10.321462] Kernel panic - not syncing:
[   10.321465] Attempted to kill init! exitcode=0x00007f00
[   10.321469] CPU: 4 PID: 1 Comm: bash Not tainted 5.15.148-tegra #1
[   10.321472] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
this usually due to mismatch key within your EKB. please see-also Topic 270934 for the steps to enable disk encryption with a custom key.
Thank you so much! If I had known this a month ago, it would have saved my hair! :)
I’ll give it a try.
Dear JerryChang,
I’m not very experienced with Liuh, and the task of setting up full-disk encryption that suddenly fell on me is almost crushing me under the huge amount of documentation I’ve had to read. Still, I’m doing my best to get full-disk encryption running. I’ve carefully gone through everything you recommended, but I still have a few questions.
In your reply to this topic:
https://forums.developer.nvidia.com/t/failing-with-custom-keys-for-encrypting-nvme-on-jetson-orin-nano/270934/13
you mentioned the following command in step (2):
$ sudo ./flash.sh --no-flash -k A_eks jetson-orin-nano-devkit internal
As I understand it, this command generates an image for QSPI flash — could you please clarify what the A_eks key actually is and what role it plays in the process?
Also, will this same procedure work with JetPack 6.2.1, or are there any differences I should be aware of?
Thank you very much for your time and support!
hello slobodenuksk,
please see-also op-tee documentation, it’s EKB (i.e. Encrypted Key Blob) for saving keys.
it’s eks_t234.img for Orin series, and flashing onto the EKS partition. (i.e. A_eks/B_eks)
as you can see of the flashing messages, it’s writing signed/encrypted binary file.
let me re-cap as below..
Writing eks_t234_sigheader.img.encrypt (parittion: A_eks) into /dev/mtd0
this is the file coming from.. $OUT/Linux_for_Tegra/tools/kernel_flash/images/internal/
you’ll need to replace this binary file since you’re re-create EKS image with your customize key.
the flow remain the same, you may follow those steps from Topic-270934 based-on JP-5
Thank you, but I have another question: I can’t insert the key into A_eks.
The command
throws the following error:
Error: Using a flash partition table config file of SD card,
/home/user/nvidia/nvidia_sdk/JetPack_6.2.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sd.xml,
but the target board does not have SD card
To bypass this error, please add your board information to the board_with_sdcard array in this script.
What should I do?
Any help would be appreciated.
Asked myself – answering myself:
The command with the given parameters executed successfully:
sudo ./flash.sh --no-flash -k A_eks -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
But unfortunately, the result is the same — during boot, the system cannot find the keys and fails to decrypt the disk.
Dear JerryChang, could you please advise whether it’s necessary to specify somewhere in the device tree that keys are required to decrypt access to the disk, or does the very presence of a record in A_eks automatically indicate this?
hello slobodenuksk,
did you fuse this target to enable Secure Boot?
or.. you only using ROOTFS_ENC=1 to enable disk encryption with your own keys?
please check you’re using the same L4T version (i.e. jetson-linux-r3644), [Driver Package (BSP) Sources] to obtain the python script.
for instance,
$public_sources/r36.4.4/Linux_for_Tegra/source/atf_and_optee/optee/samples/hwkey-agent/host/tool/gen_ekb/example.sh
please check example.sh and revise the script file with your own keys to create eks_t234.img.
since you’re using flash.sh, please do update the binary file $OUT/Linux_for_Tegra/bootloader/eks_t234.img,
and then, please running below to update EKS image.
$ sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml -k A_eks --no-systemimg jetson-orin-nano-devkit-nvme nvme0n1p1
Greetings, JerryChang!
Huge thanks! May your health stay strong for many years to come!
Thanks to your help, I managed to set up full-disk encryption, and my Jetson booted from the encrypted drive!
Now I’ll be figuring out signing and secure boot — but that’s a topic for the next thread. :)
And one more question: if I use my own carrier board and need to replace the device tree, at what stage is it best to do that?
hello slobodenuksk,
glad to know disk encryption works, please have a new discussion thread for following up.
here’re two approaches for loading device tree blob.
(1) it’s bootloader stage for loading hardware configuration settings.
please check the board configuration file, jetson-orin-nano-devkit.conf.
it’s DTB_FILE=tegra234-p3768-0000+p3767-0004-nv.dtb; property to specify the device tree for flashing onto A_kernel-dtb/B_kernel-dtb partition.
here’s the path of the binary file. $OUT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb
(2) or, you may also using device tree from root file system by UEFI,
please refer to Updating DTB Files for loading device tree blob via FDT entry.
besides..
you’ll need to download [Driver Package (BSP) Sources] to extract kernel_src.tbz2 package.
it’s $public_sources/r36.4.4/Linux_for_Tegra/source/kernel_src/hardware/nvidia/t23x/nv-public/ for Orin series device tree source files.
please see-also developer guide, Building the DTBs for the steps to rebuild the kernel and device tree blob.
Dear JerryChang,
Thank you once again for your help.
I’ll look into it.
I tried to set up full-disk encryption on a second Jetson Orin NX and ran into the same problem again – the board cannot find the correct passphrase, even though I am doing everything exactly the same way as with the first device that works perfectly.
Could you please point out where my reasoning is wrong:
  1. To encrypt the SSD image, the sym2_t234.key is required.
  2. To generate sym2_t234.key, the disk UUID and BR_CID are needed.
  3. The disk UUID changes every time a new encrypted image is written.
How can I obtain the final UUID of the disk before flashing the encrypted image (so that the correct sym2_t234.key can be generated in advance)?
Thank you very much in advance!
hello slobodenuksk,
it’s by default to have unique ECID (per device) to enable disk encryption.
if you’re going to have massflash process, see-also Topic 291335 for creating encrypted images with a generic key.
BTW,
this topic has been solved, please start a new topic instead for following up.
