I read lot of disk encryption related topic in the forums, and try different steps but it stuck at black screen after showing boot.
I’m not able to provide UART log at the moment, only console log available.
I use the optee ./sample.sh to generate the sym2_t234.key
Remove the eks_t234.img from bootloader and copy the newly generated from optee into bootloader
step 1
sudo ./flash.sh --no-flash -k A_eks -i “sym2_t234.key” cti/orin-nano/boson-orin/fsm-imx678-2cam mmcblk0p1
log1.log (21.0 KB)
step 2
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --no-flash --network usb0
log2.log (181.3 KB)
step 3
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 cti/orin-nano/boson-orin/fsm-imx678-2cam external
log3.log (141.4 KB)
step 4
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
log4.log (40.5 KB)
Hi @mrcloud ,
This should be posted in the Jetson forums. I will move it so the Jetson team has visibility.
Discussions relating to the Jetson DevKits and other Embedded computing devices
Best,
Tom
please refer to below topic also,
hello _Becu,
we’ve test again locally to confirm disk encryption is working.
here’re our test steps for your reference,
Preparation: $ sudo apt-get install cryptsetup.
note, it’s cryptsetup utility to create encrypted rootfs for image flashing.
Generate images for QSPI:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --no-flash --network usb0 jetson-orin-nano-devkit internal
Generate the key:
$ echo "f0e0d0c0b0a001020304050607…
Hi Jerry,
So actually don’t require optee? generate random sym, sym2, eks_t234.img?
Just random generate ekb.key?
hello mrcloud,
these user keys are specified in EKS image, i.e. eks_t234.img
for instance, it’s an op-tee example, optee/samples/hwkey-agent/host/tool/gen_ekb/example.sh to generate EKS image.
during booting up, a trust service (OP-TEE OS) to retrieves user keys from eks_t234.img, and loads the key into keyslots for decryption.
please see-also developer guide, Encrypted Keyblob Generation and Device Provisioning .
FYI,
EKB (Encrypted Binary Blob) stores two keys, one is the kernel encryption key (sym_key_file), and another one is the LUKS key (sym2_key_file) for disk encryption support.
LUKS disk encryption support with a specific key. you should execute the script file, gen_ekb.py to generate an image. also, in the developer guide of the OP-TEE section, [Tool for EKB Generation] that sym2.key is equivalent to ekb.key
Hi Jerry,
would like to double confirm the step of using openssl generated key and with gen_ekb to flash.
after generate using sym2_t234.key and eks_t234.img
copy sym2_t234.key
remove existing eks_t234.img and replace with new eks_t234.img into bootloader.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --no-flash --network usb0 jetson-orin-nano-devkit internal
log1.log (181.1 KB)
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 jetson-orin-nano-devkit external
log2.log (130.6 KB)
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
but at step 5, facing some error.
log3.log (7.5 KB)
hello mrcloud,
it looks EKS image did not update correctly.
according to the log file, i.e. log1.log (181.1 KB)
re-cap as below.
Existing eksfile(/home/cf/Downloads/flash8/Linux_for_Tegra/bootloader/eks_t234.img) reused.
[ 16.9515 ] Copying eks_t234_sigheader.img.encrypt to /home/cf/Downloads/flash8/Linux_for_Tegra/bootloader/signed
[ 16.9523 ] Signed file: /home/cf/Downloads/flash8/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
Copying /home/cf/Downloads/flash8/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt /home/cf/Downloads/flash8/Linux_for_Tegra/tools/kernel_flash/images/internal/eks_t234_sigheader.img.encrypt
could you please refer to Topic 270934 to have two steps approaches to create an image by flash.sh , and running l4t_initrd_flash.sh for EKS partition update.
apa
November 1, 2023, 1:17pm
9
I think @mrcloud have a point. Can you please established a step by step guide for a perfect disk encyption on any device …
mrcloud
November 1, 2023, 6:17pm
10
Hi Jerry,
I’m still not success.
Steps as below:
only generate sym2_t234 with openssl random
cp ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/sym2_t234.key ./sym2_t234.key
rm ./bootloader/eks_t234.img
cp ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/eks_t234.img ./bootloader/eks_t234.img
sudo ./flash.sh --no-flash -k A_eks jetson-agx-orin-devkit mmcblk0p1
log1.log (21.4 KB)
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --no-flash --network usb0 cti/orin-nano/boson-orin/fsm-imx678-2cam internal
log2.log (179.9 KB)
sudo cp ./bootloader/eks_t234_sigheader.img.encrypt ./tools/kernel_flash/images/internal/eks_t234_sigheader.img.encrypt
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 cti/orin-nano/boson-orin/fsm-imx678-2cam external
log3.log (140.6 KB)
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -k A_eks --flash-only --showlogs
log4.log (12.6 KB)
During device booting, there is error “Could not detect network connection”
hello mrcloud,
please re-run step-(4), (5), (7), (9). and sharing the UART logs for reference.
system
Closed
November 20, 2023, 2:20am
15
