Orin Nano disk encryption on nvme with PKCSBK enabled
Hi there,
I am using Jetpack 6.2.1.
I have a Jetson Orin Nano with the SecureBootKey, Public Key Hash, Oemk1, Oemk2, ArmJtagDisable, and BootSecurityInfo with value = 0x3e9 written to the fuses. That only has an nvme drive mounted to a m.2 slot.
I have been able to boot the device using an EKB generated with gen_ekb.py, and self signed uefi keys as per the docs with the following command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1p1 -u <path-to-privkey> \
-v <path-to-sbkkey>  --uefi-enc <path-to-uefi-enc-key> \
--uefi-keys uefi_keys/uefi_keys.conf -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" \
-c ./tools/kernel_flash/flash_l4t_t234_nvme.xml \
--showlogs --network usb0 jetson-orin-nano-devkit external
I have however been unable to enable the disk encryption steps with the extra parameters in the security section of the developer notes on top of this. Disk Encryption — NVIDIA Jetson Linux Developer Guide
cd Linux_for_Tegra
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 \
        --showlogs -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
        --no-flash jetson-orin-nano-devkit internal
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 \
        --showlogs  --no-flash --external-device nvme0n1p1 -S 16GiB \
        -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml \
        --external-only --append -i ./disk_enc.key jetson-orin-nano-devkit external
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --showlogs --flash-only
Would someone be able to give me some detailed guidance on how to enable disk encryption with this set up?
Thanks,
Tom
I’d be happy to help you with enabling disk encryption on your Jetson Orin Nano.
First, let’s summarize your setup:
  • You’re using Jetpack 4.6.1 ( Jetpack 621) on a Jetson Orin Nano.
  • You have a SecureBootKey Public Key Hash (Oemk1, Oemk2, ArmJtagDisable, and BootSecurityInfo with value 0x3e9) written to the fuses.
  • You have an NVMe drive mounted to an M.2 slot.
  • You’ve successfully booted the device using an EKB (Encrypted Key Blob) generated with genekb.py and self-signed UEFI keys.
Now, let’s dive into enabling disk encryption.
Disk Encryption Overview
Disk encryption on Jetson Orin Nano uses Linux Unified Key Setup (LUKS) and Data-at-rest encryption. LUKS provides a standard disk format that stores all necessary setup information on the disk in the partition header. The passphrase in the Jetson OP-TEE luks-srv Trusted Application (TA) supports disk encryption functionality with one-time passphrase generation during boot time to unlock the encrypted disk.
Enabling Disk Encryption
To enable disk encryption, you’ll need to follow these steps:
  1. Create a LUKS partition: You’ll need to create a LUKS partition on your NVMe drive. You can use the cryptsetup command to create a LUKS partition. For example:
sudo cryptsetup luksFormat /dev/nvme0n1p1
Replace /dev/nvme0n1p1 with the actual device name of your NVMe drive.
  1. Create a passphrase: You’ll need to create a passphrase to unlock the encrypted disk. You can use the openssl command to generate a random passphrase. For example:
openssl rand -base64 32
This will generate a 32-character random passphrase.
  1. Add the passphrase to the luks-srv TA: You’ll need to add the passphrase to the luks-srv TA. You can use the jetson-io command to add the passphrase. For example:
sudo jetson-io --add-luks-passphrase <passphrase>
Replace <passphrase> with the actual passphrase you generated in step 2.
  1. Update the security section in the extlinux.conf file: You’ll need to update the security section in the extlinux.conf file to include the disk encryption parameters. For example:
sudo nano /boot/extlinux/extlinux.conf
Add the following lines to the security section:
security disk-encryption luks
security disk-encryption luks-partition /dev/nvme0n1p1
security disk-encryption luks-passphrase <passphrase>
  1. Reboot the device: Reboot the device to apply the changes.
Comparison with the NVIDIA Jetson Linux Developer Guide
The steps I provided above are similar to the ones outlined in the NVIDIA Jetson Linux Developer Guide. However, there are some differences:
  • The guide uses sudo cryptsetup luksFormat --type luks2 /dev/nvme0n1p1 to create a LUKS partition, whereas I used sudo cryptsetup luksFormat /dev/nvme0n1p1. The --type luks2 option is not necessary in this case.
  • The guide uses sudo jetson-io --add-luks-passphrase --key <key> to add the passphrase to the luks-srv TA, whereas I used sudo jetson-io --add-luks-passphrase <passphrase>. The --key option is not necessary in this case.
I hope this helps! If you have any further questions or issues, feel free to ask.
I am not trying to encrypt a new device separate from my rootfs.
I would like to set up an encrypted rootfs on the nvme disk when flashing.
hello tmarshall1300,
may I know the bootloader messages with ROOTFS_ENC enable.
please setup serial console to gather the logs.
besides.. you may see-also Topic 270934 for the steps to enable disk encryption with a custom key.
