Secure boot step-by-step on Jetson Orin Nano (P3767-0005)
Hi, NVIDIA team
I have a question regarding the Secure boot+disk encryption on the Jetson Orin Nano board. Specifically, what cavities I may run into during the process. I’m planning to go with 36.4.3, and according to the welcome page (Welcome — NVIDIA Jetson Linux Developer Guide), the board can boot securely from USB and NVMe drives. Earlier I tried to boot with a burned PKC+ODM fuse on the P3767-0005 board but ran into a problem the board can no longer boot from the SD card. Now I’m considering re-try with the eMMC board as pointed out in the forum discussion (Secure boot on jetson nano) but isn’t obvious from the documentation. Am I right that the process will look smth like this:
  • download L4T
  • Download and unarchive the rootfs
  • ./applybinaries.sh
  • Initial flash without any additional configurations
  • Prepare the PKC+SBK+OemK1 (at this step I don’t understand the point of two keys, as per the documentation the K1 is used for EKB Generation and I’m not sure what happens if I burn OemK1+OemK2)
  • Create UEFI variable authentication auth key file and use it for gen_ekb.py
  • Prepare the PK, KEK, db Keys (Secure Boot — NVIDIA Jetson Linux Developer Guide)
  • Flash with
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -u <pkc_keyfile> [-v <sbk_keyfile>] --uefi-keys uefi_keys/uefi_keys.conf -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit external
But here is where I get lost in your documentation and not sure whether those steps are enough to achieve the secure boot and full disk encryption (either with LUKS or by other means)
hello wa1tf0r ,
please refer to below two topics for reference.
UEFI Secureboot + Rootfs AB + Disk Encryption + OTA update from r36.4.3 to r36.4.3 on Fused-Orin-Nano
