ERR! on Fan in nvidia-smi with driver 410.93
Hi! Sometimes nvidia-smi shows “ERR!” in “Fan” column like this:
| NVIDIA-SMI 410.93       Driver Version: 410.93       CUDA Version: 10.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  P106-100            On   | 00000000:02:00.0 Off |                  N/A |
|ERR!   40C    P0    59W /  60W |   3023MiB /  6080MiB |    100%      Default |
I assume that this can be related to Fan power setting to 100%. Before I used 396.45 driver version (with this version Fan percentage displayed the same way that I’ve set it (“100%”)). In new version if I set Fan speed (with nvidia-settings) to “99%”, then in nvidia-smi I see sometimes “98%”, “99%”, “100%” (somehow correlates with fan tachometer) (also if I manually block fan, then it shows “0%” and also sometimes I see “ERR!” (but rare)). There is no “ERR!” messages if I set it to, for example, 60%. My assuming is that “ERR!” happens when fan speed is something like “101%”.
NVML function nvmlDeviceGetFanSpeed in “ERR!” moments returns NVML_ERROR_UNKNOWN (999).
My OS is CoreOS v1506.0.0(alpha) (with Linux kernel v4.12.7).
Maybe someone knows how to avoid “ERR!” with “100%” Fan setting? Or maybe knows nearest driver version for CUDA 10.0 (>=410.48) that has no such problem?
I am getting same error. Did this resolve?
