Nvidia-smi 0c and err on fan col
Hi Folks,
I connected third GPU that does work. I run bunch of cuda code so GPU is fine. Also in EVGA precision x1 report temperature and all sensor but it look like nvidia-smi doesn’t read the data what might be the issue ? (notice last one)
nvidia-smi -q -d temperature
==============NVSMI LOG==============
Timestamp : Thu Jun 22 12:18:46 2023
Driver Version : 536.23
CUDA Version : 12.2
Attached GPUs : 3
GPU 00000000:01:00.0
Temperature
GPU Current Temp : 52 C
GPU T.Limit Temp : 31 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU 00000000:03:00.0
Temperature
GPU Current Temp : 43 C
GPU T.Limit Temp : 40 C
GPU 00000000:15:00.0
Temperature
GPU Current Temp : 0 C <—
GPU T.Limit Temp : N/A
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
GPU Max Operating Temp : 93 C
GPU Target Temperature : 83 C
Memory Max Operating Temp : N/A
Thu Jun 22 12:23:47 2023
| NVIDIA-SMI 536.23 Driver Version: 536.23 CUDA Version: 12.2 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 WDDM | 00000000:01:00.0 On | Off |
| 0% 50C P0 90W / 480W | 1495MiB / 24564MiB | 2% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 4090 WDDM | 00000000:03:00.0 Off | Off |
| 0% 51C P0 92W / 480W | 0MiB / 24564MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce RTX 3090 WDDM | 00000000:15:00.0 Off | N/A |
|ERR! 0C P0 61W / 420W | 0MiB / 24576MiB | 0% Default |
| | | N/A |
