When I run the command nvidia-smi -q -d TEMPERATURE on my computer, the values for GPU Shutdown, GPU Slowdown, and GPU Max Operating T.Limit Temp appear abnormal, as shown below. When I try to train a model using the GPU, I keep getting the error unable to determine the device handle for gpu . Could these two issues be related? And is the output below normal? I would appreciate any help.
==============NVSMI LOG==============
Timestamp : Sat Jul 27 23:18:53 2024
Driver Version : 550.100
CUDA Version : 12.4
Attached GPUs : 2
GPU 00000000:01:00.0
Temperature
GPU Current Temp : 35 C
GPU T.Limit Temp : 49 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 85 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU 00000000:07:00.0
Temperature
GPU Current Temp : 39 C
GPU T.Limit Temp : 46 C
