I’ve updated the CUDA SDK from 11.x to 12.6, and I’m getting the error in the title. Can anyone explain in detail what it means? Thanks!
Well, ChatGPT answered this with:
This error means that in CUDA, extended
__device__
lambdas (lambdas that can run on the GPU) are not allowed to capture variables within aconstexpr if
statement. CUDA has certain restrictions on what can be captured by device lambdas, and capturing variables in the context ofconstexpr if
introduces complexity that is not currently supported by the CUDA compiler.To resolve this, try refactoring your code so that the lambda does not rely on capturing variables in a
constexpr if
context or move the logic outside the lambda.
Which I’ll take as the correct answer unless someone says it’s not.
