undeclared variable in template crashes compiler
An undeclared variable in a template function results in a crash of the compiler.
C:\CUDA\bin>nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2007 NVIDIA Corporation
Built on Wed_Jul_16_12:57:50_PDT_2008
Cuda compilation tools, release 2.0, V0.2.1221
1>bug.cu(20): internal error: assertion failed: gen_expr: bad expr node kind (D:/Bld/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/cp_gen_be.c, line 9509)
1>1 catastrophic error detected in the compilation of “c:\tmp\junk/tmpxft_00000d2c_00000000-6_bug.cpp1.ii”.
1>Compilation aborted.
1>This application has requested the Runtime to terminate it in an unusual way.
1>Please contact the application’s support team for more information.
#include    <cutil.h>
#include    <cuda.h>
template <typename ElementType>
class CudaDoubleBuffer {
private:
   ElementType                 *DeviceBuffer2;
public:
    ElementType                 *
    GetDeviceOutputBuffer(
        if (!DeviceBuffer2) {
          cudaMalloc((void **)&DeviceBuffer2,
                      Bytecount);
       return DeviceBuffer2;
Note that changing:
to
typedef void *ElementType;
results in the correct warning for an undeclared identifier. Adding the missing declaration allows compilation to complete.
nvm. but try this: template
This results in the same crash in situ.
