Error (batch_jpeg_enc): Transformation of CUDA_DEVICE memory on different GPUs is not allowed
Description: I’m encountering a GPU memory transformation error when using the nvds_obj_enc_process function in my DeepStream application:
Error (batch_jpeg_enc): Transformation of CUDA_DEVICE memory on different gpus is not allowed. Please use either UNIFIED or PINNED memory for the transformation or do the transformation on the same gpus.
Code Context:
I use a buffer probe on the pad of nvosd.
Following along the lines of
\opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-image-meta-test\deepstream_image_meta_test.c
NvDsObjEncUsrArgs objData = {0};
objData.saveImg = TRUE;
objData.attachUsrMeta = TRUE;
objData.scaleImg = FALSE;
objData.scaledWidth = 0;
objData.scaledHeight = 0;
objData.objNum = 1;
objData.quality = 80;
objData.calcEncodeTime = TRUE;
nvds_obj_enc_process(ctx, &objData, ip_surf, obj_meta, frame_meta);
Environment:
  • Hardware Platform: GPU
  • DeepStream Version: 7.1
  • JetPack Version: Not applicable (using GPU)
  • TensorRT Version: Not specified
  • NVIDIA GPU Driver Version: 560.35.03
  • CUDA Version: 12.6
Issue Type: Bug
How to Reproduce the Issue:
  1. Use the nvds_obj_enc_process function in a DeepStream application.
  2. Configure the NvDsObjEncUsrArgs structure as shown in the code context
Question: How can I configure the nvds_obj_enc_process function or the NvDsObjEncUsrArgs structure to use UNIFIED or PINNED memory instead of CUDA_DEVICE memory? Is there a parameter I’m missing, or do I need to modify the input buffer surface memory type before calling the encoding function?
I only use on GPU with gpu_id=0
Any guidance on resolving this GPU memory transformation issue would be greatly appreciated.
Do you have multiple GPUs on your system? You can try to set CUDA_VISIBLE_DEVICES=gpu_id_which_you_want_to_use ./your_program
This is usually related to other elements in the pipeline. Can you share your pipeline?
x.pdf (31.2 KB)
Here is the pipeline. There is only one GPU.
There is no problem with the pipeline. This problem is usually caused by incorrect configuration of gpu-id. Can you share sample code to reproduce the problem? Or can deepstream_image_meta_test reproduce the problem?
deepstream_image_meta_test does not have the problem. I will investigate further. I think, it has something to do with the context.
