@developer.makarov @sarodeanil35 I also have a prototype pip server that caches the wheels built by jetson-containers now, you can find info about it here:
4/2/24 - Pip wheel server cache
In association with the points above, the number of container combinations increases exponentially, impacting the scalability of the build system to automatically redistribute binaries so not every user is spending hours/days recompiling these packages which are often tricky to build correctly.
jetson-containers now caches the pip wheels that it builds on a custom Pip server, which is used not only to install these packages into the deployment containers, …
You can download my jp6/cu122 torchvision wheel here: jp6/cu122/: torchvision-0.17.2+c1d70fe metadata and description
