hello, I’m having trouble when trying to compile torchvision from source. I mainly followed the instructions from PyTorch for Jetson - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
After I successfully installed pytorch 1.13.0 in miniconda env, I tried it and cuda is usable (torch.cuda.is_available() returns true), but when I cloned codes from pytorch/vision: Datasets, Transforms and Models specific to Computer Vision (github.com) and run setup.py, it won’t succeed, showing something wrong with c++ std ‘clamp’. Though I have looked into it, it seems nobody is having the same trouble and I really don’t know how to handle…can you help me please?
here’s basic info and error log
Python 3.8.10
cuda 11.4.315
cudnn 8.6.0.166
L4T: 35.3.1 Jetpack: 5.1.1
log
(pytorch113) sputnik-orin@sputnik-jetson-orin:~/vision-main$ python setup.py install --user
setup.py:10: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
from pkg_resources import DistributionNotFound, get_distribution, parse_version
fatal: not a git repository (or any of the parent directories): .git
Building wheel torchvision-0.14.0
Compiling extensions with following flags:
FORCE_CUDA: False
FORCE_MPS: False
DEBUG: False
TORCHVISION_USE_PNG: True
TORCHVISION_USE_JPEG: True
TORCHVISION_USE_NVJPEG: True
TORCHVISION_USE_FFMPEG: True
TORCHVISION_USE_VIDEO_CODEC: True
NVCC_FLAGS:
Compiling with debug mode OFF
Found PNG library
Building torchvision with PNG image support
libpng version: 1.6.37
libpng include path: /usr/include/libpng16
Running build on conda-build: False
Running build on conda: True
Building torchvision with JPEG image support
libjpeg include path: /home/sputnik-orin/miniconda3/envs/pytorch113/include
libjpeg lib path: /home/sputnik-orin/miniconda3/envs/pytorch113/lib
Building torchvision without NVJPEG image support
Building torchvision without ffmpeg support
Building torchvision without video codec support
running install
/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
Please avoid running ``setup.py`` directly.
Instead, use pypa/build, pypa/installer or other
standards-based tools.
See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
self.initialize_options()
/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/setuptools/_distutils/cmd.py:66: EasyInstallDeprecationWarning: easy_install command is deprecated.
Please avoid running ``setup.py`` and ``easy_install``.
See https://github.com/pypa/setuptools/issues/917 for details.
running bdist_egg
running egg_info
writing torchvision.egg-info/PKG-INFO
writing dependency_links to torchvision.egg-info/dependency_links.txt
writing requirements to torchvision.egg-info/requires.txt
writing top-level names to torchvision.egg-info/top_level.txt
/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/utils/cpp_extension.py:472: UserWarning: Attempted to use ninja as the BuildExtension backend but we could not find ninja.. Falling back to using the slow distutils backend.
warnings.warn(msg.format('we could not find ninja.'))
reading manifest file 'torchvision.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files matching '__pycache__' found under directory '*'
warning: no previously-included files matching '*.py[co]' found under directory '*'
adding license file 'LICENSE'
writing manifest file 'torchvision.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
copying torchvision/version.py -> build/lib.linux-aarch64-cpython-38/torchvision
running build_ext
building 'torchvision.image' extension
creating build/temp.linux-aarch64-cpython-38/home
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu
creating build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cuda
gcc -pthread -B /home/sputnik-orin/miniconda3/envs/pytorch113/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPNG_FOUND=1 -DJPEG_FOUND=1 -DNVJPEG_FOUND=0 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/usr/include/libpng16 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/vision-main/torchvision/csrc/io/image -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/include/python3.8 -c /home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/common_jpeg.cpp -o build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/common_jpeg.o -g0 -DTORCH_API_INCLUDE_EXTENSION_H -DPYBIND11_COMPILER_TYPE=\"_gcc\" -DPYBIND11_STDLIB=\"_libstdcpp\" -DPYBIND11_BUILD_ABI=\"_cxxabi1013\" -DTORCH_EXTENSION_NAME=image -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for C/ObjC but not for C++
gcc -pthread -B /home/sputnik-orin/miniconda3/envs/pytorch113/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPNG_FOUND=1 -DJPEG_FOUND=1 -DNVJPEG_FOUND=0 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/usr/include/libpng16 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/vision-main/torchvision/csrc/io/image -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/include/python3.8 -c /home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_image.cpp -o build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_image.o -g0 -DTORCH_API_INCLUDE_EXTENSION_H -DPYBIND11_COMPILER_TYPE=\"_gcc\" -DPYBIND11_STDLIB=\"_libstdcpp\" -DPYBIND11_BUILD_ABI=\"_cxxabi1013\" -DTORCH_EXTENSION_NAME=image -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
gcc -pthread -B /home/sputnik-orin/miniconda3/envs/pytorch113/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPNG_FOUND=1 -DJPEG_FOUND=1 -DNVJPEG_FOUND=0 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/usr/include/libpng16 -I/home/sputnik-orin/vision-main/torchvision/csrc -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/vision-main/torchvision/csrc/io/image -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/TH -I/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/THC -I/usr/local/cuda/include -I/home/sputnik-orin/miniconda3/envs/pytorch113/include/python3.8 -c /home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.cpp -o build/temp.linux-aarch64-cpython-38/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.o -g0 -DTORCH_API_INCLUDE_EXTENSION_H -DPYBIND11_COMPILER_TYPE=\"_gcc\" -DPYBIND11_STDLIB=\"_libstdcpp\" -DPYBIND11_BUILD_ABI=\"_cxxabi1013\" -DTORCH_EXTENSION_NAME=image -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.cpp: In function ‘unsigned char vision::image::{anonymous}::clamped_cmyk_rgb_convert(unsigned char, unsigned char)’:
/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.cpp:77:15: error: ‘clamp’ is not a member of ‘std’
77 | return std::clamp(k - v, 0, 255);
/home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.cpp:77:15: note: suggested alternatives:
In file included from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/Functions.h:476,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/ATen.h:13,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/torch/csrc/api/include/torch/types.h:3,
from /home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.h:3,
from /home/sputnik-orin/vision-main/torchvision/csrc/io/image/cpu/decode_jpeg.cpp:1:
/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/ops/clamp.h:31:19: note: ‘at::clamp’
31 | inline at::Tensor clamp(const at::Tensor & self, const c10::optional<at::Tensor> & min={}, const c10::optional<at::Tensor> & max={}) {
In file included from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/MethodOperators.h:100,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/core/TensorBody.h:40,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/core/Tensor.h:3,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/DeviceGuard.h:3,
from /home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/ATen.h:9,
/home/sputnik-orin/miniconda3/envs/pytorch113/lib/python3.8/site-packages/torch/include/ATen/ops/clamp_ops.h:17:18: note: ‘at::_ops::clamp’
17 | struct TORCH_API clamp {
error: command '/usr/bin/gcc' failed with exit code 1
