Description
$ python3 uff_inference.py
[TensorRT] VERBOSE: Registered plugin creator - ::BatchTilePlugin_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::BatchedNMS_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::CoordConvAC version 1
[TensorRT] VERBOSE: Registered plugin creator - ::CropAndResize version 1
[TensorRT] VERBOSE: Registered plugin creator - ::DetectionLayer_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::FlattenConcat_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::GenerateDetection_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::GridAnchor_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::GridAnchorRect_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::InstanceNormalization_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::NMS_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::Normalize_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::PriorBox_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::ProposalLayer_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::Proposal version 1
[TensorRT] VERBOSE: Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::Region_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::Reorg_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::ResizeNearest_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::RPROI_TRT version 1
[TensorRT] VERBOSE: Registered plugin creator - ::SpecialSlice_TRT version 1
[TensorRT] VERBOSE: UFFParser: mrcnn_mask_bn4/batchnorm/add_1 → [100,256,14,14]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: mrcnn_mask_bn4/batchnorm/add_1
[TensorRT] VERBOSE: UFFParser: Parsing activation_74/Relu[Op: Activation]. Inputs: mrcnn_mask_bn4/batchnorm/add_1
[TensorRT] VERBOSE: UFFParser: activation_74/Relu → [100,256,14,14]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: activation_74/Relu
[TensorRT] VERBOSE: UFFParser: Parsing mrcnn_mask_deconv/conv2d_transpose[Op: ConvTranspose]. Inputs: mrcnn_mask_deconv/kernel, mrcnn_mask_deconv/stack, activation_74/Relu
[TensorRT] VERBOSE: UFFParser: Inserting transposes for mrcnn_mask_deconv/conv2d_transpose
[TensorRT] ERROR: UffParser: Parser error: mrcnn_mask_deconv/conv2d_transpose: Invalid shape
[TensorRT] ERROR: Network must have at least one output
[TensorRT] ERROR: Network validation failed.
File “uff_inference.py”, line 96, in
inputs, outputs, bindings, stream = allocate_buffers(engine)
File “uff_inference.py”, line 54, in allocate_buffers
for binding in engine:
TypeError: ‘NoneType’ object is not iterable
Environment
TensorRT Version: 7.1.34
GPU Type: GeForce GTX 1080 Ti
Nvidia Driver Version: 440.33.01
CUDA Version: 10.2
CUDNN Version: 8.0.5
Operating System + Version: ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15.0
Relevant Files
mrcnn_nchw.uff - Google Drive << model
uff_inference.py - Google Drive << inference code
Steps To Reproduce
TensorRT/samples/opensource/sampleUffMaskRCNN at release/7.1 · NVIDIA/TensorRT · GitHub << how to convert the pretrained .h5 model to mrcnn_nchw.uff above
run:
# on local ubuntu environment out of docker container
Please help. Thank you.
