Description
I’m trying to convert my onnx model to TensorRT engine model but getting error for one unsupported layer.
[06/06/2020-14:42:34] [W] [TRT] onnx2trt_utils.cpp:217: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[06/06/2020-14:42:34] [W] [TRT] onnx2trt_utils.cpp:243: One or more weights outside the range of INT32 was clamped
[06/06/2020-14:42:34] [W] [TRT] ModelImporter.cpp:135: No importer registered for op: ReverseSequence. Attempting to import as plugin.
[06/06/2020-14:42:34] [I] [TRT] builtin_op_importers.cpp:3556: Searching for plugin: ReverseSequence, plugin_version: 001, plugin_namespace:
[06/06/2020-14:42:34] [E] [TRT] INVALID_ARGUMENT: getPluginCreator could not find plugin ReverseSequence version 001
ERROR: builtin_op_importers.cpp:3558 In function importFallbackPluginImporter:
[8] Assertion failed: creator && “Plugin not found”
[06/06/2020-14:42:34] [E] Failed to parse onnx file
[06/06/2020-14:42:34] [E] Parsing model failed
[06/06/2020-14:42:34] [E] Engine creation failed
[06/06/2020-14:42:34] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # ./trtexec --onnx=/home/Downloads/model.onnx --shapes=input_1:32x3x244x244
Relevant Files
Here is the onnx model file attached:
Can you tell me what’s wrong in this model? What I can do to convert this into TensorRT engine ?
