Description
I installed TensorRT, built the MNIST sample file TensorRT-7.2.3.4/samples/sampleMNIST/sampleMNIST.cpp
with make 4.1
make TRT_LIB_DIR=[absolute-path-to]/TensorRT-7.2.3.4/lib CUDA_INSTALL_DIR=/usr/local/cuda CUDNN_INSTALL_DIR=/usr/local/cuda
and ran its executable
TensorRT-7.2.3.4/bin/sample_mnist
this problem occured
CUDA initialization failure with error 222. Please check your CUDA installation: CUDA Installation Guide for Linux
I have another project compiled and ran with PyTorch C++. It’s working fine.
here trtexec logs:
&&&& RUNNING TensorRT.trtexec # ./trtexec --verbose --onnx=resnet50.onnx
[05/19/2021-04:14:51] [I] === Model Options ===
[05/19/2021-04:14:51] [I] Format: ONNX
[05/19/2021-04:14:51] [I] Model: resnet50.onnx
[05/19/2021-04:14:51] [I] Output:
[05/19/2021-04:14:51] [I] === Build Options ===
[05/19/2021-04:14:51] [I] Max batch: explicit
[05/19/2021-04:14:51] [I] Workspace: 16 MiB
[05/19/2021-04:14:51] [I] minTiming: 1
[05/19/2021-04:14:51] [I] avgTiming: 8
[05/19/2021-04:14:51] [I] Precision: FP32
[05/19/2021-04:14:51] [I] Calibration:
[05/19/2021-04:14:51] [I] Refit: Disabled
[05/19/2021-04:14:51] [I] Safe mode: Disabled
[05/19/2021-04:14:51] [I] Save engine:
[05/19/2021-04:14:51] [I] Load engine:
[05/19/2021-04:14:51] [I] Builder Cache: Enabled
[05/19/2021-04:14:51] [I] NVTX verbosity: 0
[05/19/2021-04:14:51] [I] Tactic sources: Using default tactic sources
[05/19/2021-04:14:51] [I] Input(s)s format: fp32:CHW
[05/19/2021-04:14:51] [I] Output(s)s format: fp32:CHW
[05/19/2021-04:14:51] [I] Input build shapes: model
[05/19/2021-04:14:51] [I] Input calibration shapes: model
[05/19/2021-04:14:51] [I] === System Options ===
[05/19/2021-04:14:51] [I] Device: 0
[05/19/2021-04:14:51] [I] DLACore:
[05/19/2021-04:14:51] [I] Plugins:
[05/19/2021-04:14:51] [I] === Inference Options ===
[05/19/2021-04:14:51] [I] Batch: Explicit
[05/19/2021-04:14:51] [I] Input inference shapes: model
[05/19/2021-04:14:51] [I] Iterations: 10
[05/19/2021-04:14:51] [I] Duration: 3s (+ 200ms warm up)
[05/19/2021-04:14:51] [I] Sleep time: 0ms
[05/19/2021-04:14:51] [I] Streams: 1
[05/19/2021-04:14:51] [I] ExposeDMA: Disabled
[05/19/2021-04:14:51] [I] Data transfers: Enabled
[05/19/2021-04:14:51] [I] Spin-wait: Disabled
[05/19/2021-04:14:51] [I] Multithreading: Disabled
[05/19/2021-04:14:51] [I] CUDA Graph: Disabled
[05/19/2021-04:14:51] [I] Separate profiling: Disabled
[05/19/2021-04:14:51] [I] Skip inference: Disabled
[05/19/2021-04:14:51] [I] Inputs:
[05/19/2021-04:14:51] [I] === Reporting Options ===
[05/19/2021-04:14:51] [I] Verbose: Enabled
[05/19/2021-04:14:51] [I] Averages: 10 inferences
[05/19/2021-04:14:51] [I] Percentile: 99
[05/19/2021-04:14:51] [I] Dump refittable layers:Disabled
[05/19/2021-04:14:51] [I] Dump output: Disabled
[05/19/2021-04:14:51] [I] Profile: Disabled
[05/19/2021-04:14:51] [I] Export timing to JSON file:
[05/19/2021-04:14:51] [I] Export output to JSON file:
[05/19/2021-04:14:51] [I] Export profile to JSON file:
[05/19/2021-04:14:51] [I] === Device Information ===
[05/19/2021-04:14:51] [I] Selected Device: Tesla T4
[05/19/2021-04:14:51] [I] Compute Capability: 7.5
[05/19/2021-04:14:51] [I] SMs: 40
[05/19/2021-04:14:51] [I] Compute Clock Rate: 1.59 GHz
[05/19/2021-04:14:51] [I] Device Global Memory: 15109 MiB
[05/19/2021-04:14:51] [I] Shared Memory per SM: 64 KiB
[05/19/2021-04:14:51] [I] Memory Bus Width: 256 bits (ECC enabled)
[05/19/2021-04:14:51] [I] Memory Clock Rate: 5.001 GHz
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Proposal version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::Split version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[05/19/2021-04:14:51] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[05/19/2021-04:14:51] [E] [TRT] CUDA initialization failure with error 222. Please check your CUDA installation: CUDA Installation Guide for Linux
[05/19/2021-04:14:51] [E] Builder creation failed
[05/19/2021-04:14:51] [E] Engine creation failed
[05/19/2021-04:14:51] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # ./trtexec --verbose --onnx=resnet50.onnx
LD_LIBRARY_PATH:
/usr/local/cuda/lib64:[absolute-path-to]/TensorRT-7.2.3.4/lib
Environment
TensorRT Version: TensorRT-7.2.3.4
GPU Type: NVIDIA Tesla T4
Nvidia Driver Version: 450.119.03
CUDA Version: 11.1.1
CUDNN Version: 8.1.1
Operating System + Version: Ubuntu 18.04 LTS x86_64
Baremetal or Container (if container which image + tag): Baremetal
PyTorch C++: 1.8.1 CUDA 11.1
g++: 7.5.0
cmake: 3.10.2
Steps To Reproduce
I installed CUDA Toolkit 11.1.1
with Runfile:
sudo sh cuda_11.1.1_455.32.00_linux.run --silent --toolkit --toolkitpath=/usr/local/cuda-11.1.1 --override
sudo ln -s /usr/local/cuda-11.1.1 /usr/local/cuda
CUDNN 8.1.1
tar -zvxf cudnn-11.2-linux-x64-v8.1.1.33.tgz
sudo cp cuda/include/cudnn*.h /usr/local/cuda-11.1.1/include
sudo cp -P cuda/lib64/libcudnn* /usr/local/cuda-11.1.1/lib64
sudo chmod a+r /usr/local/cuda-11.1.1/include/cudnn*.h /usr/local/cuda-11.1.1/lib64/libcudnn*
TensorRT-7.2.3.4
tar -zvxf TensorRT-7.2.3.4.Ubuntu-18.04.x86_64-gnu.cuda-11.1.cudnn8.1.tar.gz
