I’m trying to run multithreading with TensorRT by modifying this example to run with 2 (or more) threads at the same time. The code currently runs fine and shows correct results but the error
always happens when finishing. Is there anyway to fix this? Thank you in advance.
Here is my modified code:
my_tensorrt_code.py:
from PIL import Image
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda
import threading
import time
import math
class TRTInference:
def __init__(self, trt_engine_path, trt_engine_datatype, batch_size):
self.cfx = cuda.Device(0).make_context()
stream = cuda.Stream()
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
trt.init_libnvinfer_plugins(TRT_LOGGER, '')
runtime = trt.Runtime(TRT_LOGGER)
# deserialize engine
with open(trt_engine_path, 'rb') as f:
buf = f.read()
engine = runtime.deserialize_cuda_engine(buf)
context = engine.create_execution_context()
# prepare buffer
host_inputs = []
cuda_inputs = []
host_outputs = []
cuda_outputs = []
bindings = []
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
host_mem = cuda.pagelocked_empty(size, np.float32)
cuda_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(cuda_mem))
if engine.binding_is_input(binding):
host_inputs.append(host_mem)
cuda_inputs.append(cuda_mem)
else:
host_outputs.append(host_mem)
cuda_outputs.append(cuda_mem)
# store
self.stream = stream
self.context = context
self.engine = engine
self.host_inputs = host_inputs
self.cuda_inputs = cuda_inputs
self.host_outputs = host_outputs
self.cuda_outputs = cuda_outputs
self.bindings = bindings
def infer(self, input_img_path):
threading.Thread.__init__(self)
self.cfx.push()
# restore
stream = self.stream
context = self.context
engine = self.engine
host_inputs = self.host_inputs
cuda_inputs = self.cuda_inputs
host_outputs = self.host_outputs
cuda_outputs = self.cuda_outputs
bindings = self.bindings
# read image
image = 1 - (np.asarray(Image.open(input_img_path), dtype=np.float) / 255)
np.copyto(host_inputs[0], image.ravel())
# inference
start_time = time.time()
cuda.memcpy_htod_async(cuda_inputs[0], host_inputs[0], stream)
context.execute_async(bindings=bindings, stream_handle=stream.handle)
cuda.memcpy_dtoh_async(host_outputs[0], cuda_outputs[0], stream)
stream.synchronize()
print("execute times " + str(time.time() - start_time))
# parse output
output = np.array([math.exp(o) for o in host_outputs[0]])
output /= sum(output)
for i in range(len(output)): print("%d: %.2f" % (i, output[i]))
self.cfx.pop()
def destory(self):
self.cfx.pop()
test.py:
import threading
import time
from my_tensorrt_code import TRTInference, trt
exitFlag = 0
class myThread(threading.Thread):
def __init__(self, func, args):
self.func = func
self.args = args
def run(self):
print("Starting " + self.args[0])
self.func(*self.args)
print("Exiting " + self.args[0])
if __name__ == '__main__':
# Create new threads
format thread:
- func: function names, function that we wished to use
- arguments: arguments that will be used for the func's arguments
trt_engine_path = 'mnist.trt'
max_batch_size = 1
trt_inference_wrapper1 = TRTInference(trt_engine_path,
trt_engine_datatype=trt.DataType.FLOAT,
batch_size=max_batch_size)
trt_inference_wrapper2 = TRTInference(trt_engine_path,
# Get TensorRT SSD model output
input_img_path1 = 'pgms/3.pgm'
input_img_path2 = 'pgms/1.pgm'
thread1 = myThread(trt_inference_wrapper1.infer, [input_img_path1])
thread2 = myThread(trt_inference_wrapper2.infer, [input_img_path2])
# Start new Threads
thread1.start()
thread2.start()
thread1.join()
thread2.join()
trt_inference_wrapper1.destory()
trt_inference_wrapper2.destory()
print("Exiting Main Thread")
Here is the output when running:
vinhtq115@Dell-G7-7588:~/PycharmProjects/TensorRT-multithreading$ python test.py
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +150, GPU +0, now: CPU 175, GPU 197 (MiB)
[TensorRT] INFO: Loaded engine size: 0 MB
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 175 MiB, GPU 197 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +230, GPU +94, now: CPU 405, GPU 293 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +185, GPU +80, now: CPU 590, GPU 373 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 590, GPU 357 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine end: CPU 590 MiB, GPU 357 MiB
[TensorRT] INFO: [MemUsageSnapshot] ExecutionContext creation begin: CPU 590 MiB, GPU 357 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 590, GPU 365 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 590, GPU 373 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] ExecutionContext creation end: CPU 590 MiB, GPU 373 MiB
[TensorRT] WARNING: The logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. TensorRT maintains only a single logger pointer at any given time, so the existing value, which can be retrieved with getLogger(), will be used instead. In order to use a new logger, first destroy all existing builder, runner or refitter objects.
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +40, GPU +0, now: CPU 635, GPU 496 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 635 MiB, GPU 496 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +33, GPU +48, now: CPU 669, GPU 546 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +72, GPU +82, now: CPU 741, GPU 628 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 773, GPU 656 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine end: CPU 773 MiB, GPU 656 MiB
[TensorRT] INFO: [MemUsageSnapshot] ExecutionContext creation begin: CPU 773 MiB, GPU 656 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 773, GPU 664 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 773, GPU 672 (MiB)
[TensorRT] INFO: [MemUsageSnapshot] ExecutionContext creation end: CPU 773 MiB, GPU 672 MiB
Starting pgms/3.pgm
Starting pgms/1.pgm
execute times 0.0002894401550292969
0: 0.00
1: 0.00
2: 0.00
3: 1.00
execute times 0.0002601146697998047
4: 0.00
0: 0.00
5: 0.00
6: 0.00
7: 0.00
1: 1.00
2: 0.00
8: 0.00
3: 0.00
9: 0.00
4: 0.00
Exiting pgms/3.pgm
5: 0.00
6: 0.00
7: 0.00
8: 0.00
9: 0.00
Exiting pgms/1.pgm
Exiting Main Thread
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 951, GPU 874 (MiB)
