I have this python code that will fire up 3 threads, 1 for face detection and 2 for face recognition, each thread will have its own model/engine. So far, the code works fine but whenever I trigger exiting (by pressing q), it always get Segmentation fault (core dumped). Is there anyway to fix this?
vinhtq115@Dell-G7-7588:~/PycharmProjects/FaceTensorRT$ python multithreading.py
Loading embeddings: 100%|██████████████████| 18/18 [00:00<00:00, 391.32people/s]
[Detection thread] Reading engine from file weights/yolov5n-0.5.trt
[Recognition thread 0] Reading engine from file weights/arcface_mbf_fp16.trt
[TensorRT] WARNING: The logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. TensorRT maintains only a single logger pointer at any given time, so the existing value, which can be retrieved with getLogger(), will be used instead. In order to use a new logger, first destroy all existing builder, runner or refitter objects.
[Recognition thread 1] Reading engine from file weights/arcface_mbf_fp16.trt
[Recognition thread 0] Ready!
[Recognition thread 1] Ready!
All recognition threads ready. Starting detection process...
Exiting main thread.
[TensorRT] INTERNAL ERROR: [defaultAllocator.cpp::free::85] Error Code 1: Cuda Runtime (invalid argument)
[TensorRT] INTERNAL ERROR: [resources.h::operator()::445] Error Code 1: Cuda Driver (invalid device context)
Current code:
import cv2
import numpy as np
import os
import pycuda.driver as cuda
import tensorrt as trt
import threading
import time
from queue import Queue, Empty
from tqdm import tqdm
from Processing.ArcfaceProcessing import ArcfacePreProcessing, normalize
from Processing.YoloProcessing import YoloPreProcess, YoloPostProcess
from tensorrt_common import allocate_buffers, Do_Inference
cuda.init()
device = cuda.Device(0)
ctx = device.make_context()
class DetectionThread(threading.Thread):
def __init__(self, yolo_trt_engine_path: str, queues: [Queue], ready_events: [threading.Event],
exit_event: threading.Event, conf_thres=0.7, iou_thres=0.5):
super().__init__()
self.cap = cv2.VideoCapture('test.mp4')
self.queues = queues
self.ready_events = ready_events
self.exit_event = exit_event
self.num_recognition_threads = len(queues)
self.queue_count = 0 # Round-robin
self.yolo_preprocess = YoloPreProcess()
self.yolo_postprocess = YoloPostProcess(shape=(640, 640), orig_shape=(720, 1280),
conf_thres=conf_thres, iou_thres=iou_thres, device='cpu')
# Initialize YOLO
TRT_LOGGER = trt.Logger()
self.yolo_engine = None
if os.path.exists(yolo_trt_engine_path):
print(f'[Detection thread] Reading engine from file {yolo_trt_engine_path}')
with open(yolo_trt_engine_path, 'rb') as f, trt.Runtime(TRT_LOGGER) as runtime:
self.yolo_engine = runtime.deserialize_cuda_engine(f.read())
if self.yolo_engine is None:
print(f'[Detection thread] Failed to read engine from file!')
exit(1)
def run(self):
ctx.push()
# Wait for all recognition threads to be ready
for i in range(self.num_recognition_threads):
while not self.ready_events[i].is_set():
time.sleep(0.01)
print('All recognition threads ready. Starting detection process...')
with self.yolo_engine.create_execution_context() as yolo_context:
yolo_inputs, yolo_outputs, yolo_bindings, yolo_stream = allocate_buffers(self.yolo_engine)
while True:
start_time = time.time()
ret, frame = self.cap.read()
if not ret:
self.exit_event.set()
break
out_frame = frame.copy() # For drawing bounding boxes.
# Preprocess frame
p_frame = self.yolo_preprocess(frame)
# Inference
yolo_inputs[0].host = p_frame.reshape(-1)
trt_outputs = Do_Inference(yolo_context, yolo_bindings, yolo_inputs, yolo_outputs, yolo_stream)
# Postprocess
pred = self.yolo_postprocess(trt_outputs)
for i in range(len(pred)):
face_coor = pred[i]['face']
landmarks = pred[i]['landmark']
self.queues[self.queue_count].put((frame, landmarks))
self.queue_count = (self.queue_count + 1) % self.num_recognition_threads
# Draw rectangle around face
cv2.rectangle(out_frame, (face_coor[0], face_coor[1]), (face_coor[2], face_coor[3]), (0, 255, 0), 3)
# Display the resulting frame
end_time = time.time()
cv2.putText(out_frame, '{:.3f}'.format(1.0 / (end_time - start_time)), (0, 25),
cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2, cv2.LINE_AA)
cv2.imshow('Face Detection', out_frame)
# Exit if 'q' is pressed
if cv2.waitKey(1) & 0xFF == ord('q'):
break
print(f'[Detection thread] Received exit signal.')
ctx.pop()
class RecognitionThread(threading.Thread):
def __init__(self, arcface_trt_engine_path, embeddings, embeddings_map, queue: Queue,
exit_event: threading.Event, recognition_ready_event: threading.Event, id: int):
super().__init__()
self.embeddings = embeddings
self.embeddings_map = embeddings_map
self.id = id
self.queue = queue
self.recognition_ready_event = recognition_ready_event
self.arcface_preprocess = ArcfacePreProcessing()
self.sleep_time = 0.001
# Initialize ArcFace
self.arcface_engine = None
if os.path.exists(arcface_trt_engine_path):
print(f'[Recognition thread {id}] Reading engine from file {arcface_trt_engine_path}')
with open(arcface_trt_engine_path, "rb") as f, \
self.arcface_engine = runtime.deserialize_cuda_engine(f.read())
if self.arcface_engine is None:
print(f'[Recognition thread {id}] Failed to read engine from file!')
exit(1)
def run(self):
ctx.push()
self.recognition_ready_event.set()
print(f'[Recognition thread {self.id}] Ready!')
with self.arcface_engine.create_execution_context() as arcface_context:
arcface_inputs, arcface_outputs, arcface_bindings, arcface_stream = allocate_buffers(self.arcface_engine)
while not self.exit_event.is_set():
try:
frame, landmarks = self.queue.get(block=False)
except Empty:
time.sleep(self.sleep_time)
continue
face = self.arcface_preprocess(frame, landmarks)
face = cv2.cvtColor(face, cv2.COLOR_BGR2RGB)
arcface_inputs[0].host = self.arcface_preprocess.prepare(face, fp16=True)
embedding = Do_Inference(arcface_context, arcface_bindings, arcface_inputs,
arcface_outputs, arcface_stream)[0]
embedding = normalize(embedding)
cos_similarity = np.dot(self.embeddings, embedding.T).clip(min=0, max=1)
idx = np.argmax(cos_similarity, axis=0)
name = self.embeddings_map[idx]
score = cos_similarity[idx]
print(f'[Recognition thread {self.id}] Detected {name} with a score of {score}. '
f'Queue remaining items: {self.queue.qsize()}.')
print(f'[Recognition thread {self.id}] Received exit signal.')
ctx.pop()
if __name__ == '__main__':
yolo_trt_engine_path = 'weights/yolov5n-0.5.trt'
arcface_trt_engine_path = 'weights/arcface_mbf_fp16.trt'
embeddings_root = 'embeddings' # Path to embeddings
# Load embeddings
embeddings = []
embeddings_map = [] # name
for sub_folder in tqdm(os.listdir(embeddings_root), desc='Loading embeddings', unit='people'):
# sub_folder = class
for root, dirs, files in os.walk(os.path.join(embeddings_root, sub_folder)):
for file in files:
embed = np.load(os.path.join(root, file))
embeddings.append(embed)
embeddings_map.append(sub_folder)
embeddings = np.array(embeddings)
# Setup threading
recognition_thread_nums = 2
queue_size = 10
queues = [Queue(queue_size) for _ in range(recognition_thread_nums)]
exit_event = threading.Event() # For exiting
recognition_ready_events = [threading.Event() for _ in range(recognition_thread_nums)]
# Init threads
detection_thread = DetectionThread(yolo_trt_engine_path, queues, recognition_ready_events, exit_event)
recognition_threads = [RecognitionThread(arcface_trt_engine_path, embeddings, embeddings_map, queues[i],
exit_event, recognition_ready_events[i], i)
for i in range(recognition_thread_nums)]
# Start threads
[thread.start() for thread in recognition_threads]
detection_thread.start()
detection_thread.join()
[thread.join() for thread in recognition_threads]
print('Exiting main thread.')
tensorrt_common.py:
import pycuda.autoinit
def Init_TensorRT(trt_path):
with open(trt_path, 'rb') as f, \
context = engine.create_execution_context()
inputs, outputs, bindings, stream = allocate_buffers(engine)
return [context, inputs, outputs, bindings, stream]
def allocate_buffers(engine):
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
host_mem: cpu memory
device_mem: gpu memory
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
inputs, outputs, bindings = [], [], []
stream = cuda.Stream()
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def Do_Inference(context, bindings, inputs, outputs, stream):
[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
context.execute_async_v2(bindings=bindings, stream_handle=stream.handle)
[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
stream.synchronize()
return [out.host for out in outputs]
