Why tensorrt got stuck when using ThreadPool in Python
Description
After reference this draft and this draft I wrote codes as below. The code got stuck when using thread pool.
Can any one help out how to make it work properly?
And I won’t my model to serve by flask frame with multithreading.
import numpy as np
import tensorrt as trt
from cuda import cuda, cudart
import threading
def check_cuda_err(err):
    if isinstance(err, cuda.CUresult):
        if err != cuda.CUresult.CUDA_SUCCESS:
            raise RuntimeError("Cuda Error: {}".format(err))
    elif isinstance(err, cudart.cudaError_t):
        if err != cudart.cudaError_t.cudaSuccess:
            raise RuntimeError("Cuda Runtime Error: {}".format(err))
    else:
        raise RuntimeError("Unknown error type: {}".format(err))
def cuda_call(call):
    err, res = call[0], call[1:]
    check_cuda_err(err)
    if len(res) == 1:
        res = res[0]
    return res
class HostDeviceMem:
    def __init__(self, shape, dtype):
        self.shape = shape
        self.dtype = dtype
        size = trt.volume(shape) * dtype.itemsize
        self.device = cuda_call(cudart.cudaMalloc(size))
class TrtModel:
    def __init__(self, model_path, device_id=0):
        err, = cuda.cuInit(0)
        check_cuda_err(err)
        device = cuda_call(cuda.cuDeviceGet(device_id))
        self.ctx = cuda_call(cuda.cuCtxCreate(cuda.CUctx_flags.CU_CTX_SCHED_YIELD, device))
        self.logger = trt.Logger(trt.Logger.ERROR)
        trt.init_libnvinfer_plugins(self.logger, namespace="")
        with open(model_path, 'rb') as f, trt.Runtime(self.logger) as runtime:
            assert runtime, 'Can not create TensorRT Runtime'
            self.engine = runtime.deserialize_cuda_engine(f.read())
        assert self.engine, 'Can not load engine file'
        self.context = self.engine.create_execution_context()
        assert self.context, 'Can not create execution context'
        self.inputs, self.outputs, self.bindings, self.stream, self.max_batch_size = self.allocate_buffers(self.engine)
    @property
    def input_names(self):
        return list(self.inputs.keys())
    @property
    def output_names(self):
        return list(self.outputs.keys())
    def allocate_buffers(self, engine: trt.ICudaEngine):
        inputs = {}
        outputs = {}
        bindings = []
        stream = cuda_call(cudart.cudaStreamCreate())
        max_batch_size = 1
        for i in range(engine.num_io_tensors):
            name = engine.get_tensor_name(i)
            is_input = engine.get_tensor_mode(name) == trt.TensorIOMode.INPUT
            dtype = np.dtype(trt.nptype(engine.get_tensor_dtype(name)))
            shape = self.context.get_tensor_shape(name)
            if is_input and shape[0] < 0:
                assert engine.num_optimization_profiles > 0, 'Engine dynamic axes but no optimization profiles ' \
                                                             'exists '
                profile_shape = engine.get_tensor_profile_shape(name, 0)
                assert len(profile_shape) == 3  # min,opt,max
                # Set the *max* profile as binding shape
                self.context.set_input_shape(name, profile_shape[2])
            if is_input:
                max_batch_size = shape[0]
            # Allocate host and device buffers
            binding_memory = HostDeviceMem(shape, dtype)
            # Append the device buffer to device bindings.
            bindings.append(int(binding_memory.device))
            # Append to the appropriate list.
            if engine.get_tensor_mode(name) == trt.TensorIOMode.INPUT:
                inputs[name] = binding_memory
            else:
                outputs[name] = binding_memory
        return inputs, outputs, bindings, stream, max_batch_size
    def _inference(self, output_names, input_feed: dict):
        kind = cudart.cudaMemcpyKind.cudaMemcpyHostToDevice
        batch_size = self.max_batch_size
        for name, value in self.inputs.items():  # make sure we set all inputs required
            feed = input_feed[name]
            value.host = feed
            assert feed.dtype == value.dtype, 'Wrong dtype, {} expected'.format(value.dtype)
            feed = np.ascontiguousarray(feed)
            self.context.set_input_shape(name, feed.shape)
            batch_size = min(batch_size, feed.shape[0])
            num_bytes = trt.volume(feed.shape) * value.dtype.itemsize
            cuda_call(cudart.cudaMemcpyAsync(value.device, feed, num_bytes, kind, self.stream))
        self.context.execute_async_v2(bindings=self.bindings, stream_handle=self.stream)
        kind = cudart.cudaMemcpyKind.cudaMemcpyDeviceToHost
        results = []
        for key in output_names:
            out = self.outputs[key]
            shape = self.context.get_tensor_shape(key)
            out_batch_size = min(shape[0], batch_size)
            shape = out_batch_size, *shape[1:]
            num_bytes = trt.volume(shape) * out.dtype.itemsize
            host = np.zeros(shape, dtype=out.dtype)
            cuda_call(cudart.cudaMemcpyAsync(host, out.device, num_bytes, kind, self.stream))
            results.append(host)
        cuda_call(cudart.cudaStreamSynchronize(self.stream))
        return results
    def _chunk(self, input_feed: dict):
        batch_size = next(iter(input_feed.values())).shape[0]
        results = {}
        for key, value in input_feed.items():  # we don't check input batch size consistency
            chunks = [value[i: i + self.max_batch_size] for i in range(0, batch_size, self.max_batch_size)]
            results[key] = chunks
        # dict of list to list of dict
        return [dict(zip(results, t)) for t in zip(*results.values())]
    def run(self, output_names, input_feed: dict):
        threading.Thread.__init__(self)
        cuda.cuCtxPushCurrent(self.ctx)
        """Chunk input by max batch size, and inference sequentially"""
        if next(iter(input_feed.values())).shape[0] <= self.max_batch_size:
            return self._inference(output_names, input_feed)
        input_feeds = self._chunk(input_feed)
        results = [self._inference(output_names, inp) for inp in input_feeds]
        cuda.cuCtxPopCurrent()
        return [np.concatenate(v, axis=0) for v in zip(*results)]
if __name__ == '__main__':
    import numpy as np
    from multiprocessing.pool import ThreadPool
    model = TrtModel('path/to/model.engine', device_id=2)
    model2 = TrtModel('another model', device_id=3)
    inputs = np.random.rand(32, 3, 112, 112).astype(np.float32)
    while True:
        with ThreadPool(5) as pool:
            res1 = [pool.apply_async(model.run, (model.output_names, {model.input_names[0]: inputs})) for _ in range(5)]
            res2 = [pool.apply_async(model2.run, (model2.output_names, {model2.input_names[0]: inputs})) for _ in range(5)]
            res = res1 + res2
            for v in res:
                v = v.get()
                print(v[0].shape)
Environment
TensorRT Version: 8.6.1
GPU Type: A6000
Nvidia Driver Version:
CUDA Version: V11.2.152
CUDNN Version:
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8.13
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag): Container
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Just run the script with your engine files to reproduce
The below links might be useful for you.
https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__STREAM.html
For multi-threading/streaming, will suggest you to use Deepstream or TRITON
For more details, we recommend you raise the query in Deepstream forum.
or
raise the query in Triton Inference Server Github instance issues section.
