Description
class Stream:
def __init__(self,camera, detector):
self.camera = cv2.VideoCapture(camera)
self.grabbed, self.frame = self.camera.read()
self.stopped = False
self.detector = detector
def start_reading(self):
Starts a new thread to read frames
Thread(target=self.read_frames, args=()).start()
return self
def read_frames(self):
Method called in a thread to continually read frames from `self.cap`.
This way, a frame is always ready to be read. Frames are not queued;
if a frame is not read before `read_frames()` reads a new frame, previous
frame is overwritten.
while not self.stopped:
if not self.grabbed:
self.stop()
else:
self.detector.infer(self.frame)
def stop(self):
self.stopped = True
self.detector.infer(self.frame) is failing when run inside the class.
I get the following outputs:
[12/30/2022-19:13:05] [TRT] [E] 1: [reformat.cpp::executeCutensor::384] Error Code 1: CuTensor (Internal cuTensor permutate execute failed)
[12/30/2022-19:13:05] [TRT] [E] 1: [checkMacros.cpp::catchCudaError::278] Error Code 1: Cuda Runtime (invalid resource handle)
However, when I run inference with the TRT detector outside of the class on Stream.frame in main(), it works fine.
Environment
TensorRT Version: 8.4.1
GPU Type: Jetson Orin AGX
Nvidia Driver Version:
CUDA Version: 11.4
CUDNN Version:
Operating System + Version: Jetpack 5.0.2
Python Version (if applicable): 3.8
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
