TensorRT 8 segmentation fault when creating two contexts concurrently
Description
I’m using TensorRT 8 python API and when I create two contexts concurrently, it throws a segmentation fault.
Environment
TensorRT Version: 8.0.0.3
GPU Type: T4
Nvidia Driver Version: 450
CUDA Version: 11.0
CUDNN Version: 8.2.0
Operating System + Version: CENTOS 7
Python Version (if applicable): 3.7.10
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
I have two engines as shown below.
engine1.trt (2.5 MB)
engine2.trt (3.2 MB)
Steps To Reproduce
Here is the code to reproduce.
import numpy as np
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda:
class HostDeviceMem(object):
    def __init__(self, host_mem, device_mem):
        """Within this context, host_mom means the cpu memory and device means the GPU memory
        self.host = host_mem
        self.device = device_mem
    def __str__(self):
        return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
    def __repr__(self):
        return self.__str__()
class TRTInference:
    def __init__(self, engine_file_path, model, batch_size=1):
        self.engine_file_path = engine_file_path
        self.model = model
        self.batch_size = batch_size
        self.TRT_LOGGER = trt.Logger()
        self.engine = self.get_engine()
        self.context = self.get_context()
        self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
    def get_engine(self):
        with open(self.engine_file_path, "rb") as f, trt.Runtime(self.TRT_LOGGER) as runtime:
            return runtime.deserialize_cuda_engine(f.read())
    def get_context(self):
        return self.engine.create_execution_context()
    def allocate_buffers(self):
        inputs = []
        outputs = []
        bindings = []
        stream = cuda.Stream()
        for binding in self.engine:
            if self.engine.binding_is_input(binding):
                if self.model == "model2":
                    size = trt.volume([1, 3, 224, 224]) * self.engine.max_batch_size
                else:
                    size = trt.volume([1, 3, 320, 240]) * self.engine.max_batch_size
            else:
                    size = trt.volume([1, 2]) * self.engine.max_batch_size
                else:
                    output_shape = self.engine.get_binding_shape(binding)
                    size = trt.volume([1, 4420, output_shape[-1]]) * self.engine.max_batch_size
            dtype = trt.nptype(self.engine.get_binding_dtype(binding))
            # Allocate host and device buffers
            host_mem = cuda.pagelocked_empty(size, dtype)
            device_mem = cuda.mem_alloc(host_mem.nbytes)
            # Append the device buffer to device bindings.
            bindings.append(int(device_mem))
            # Append to the appropriate list.
                inputs.append(HostDeviceMem(host_mem, device_mem))
            else:
                outputs.append(HostDeviceMem(host_mem, device_mem))
        return inputs, outputs, bindings, stream
    def do_inference(self, img, img_h, img_w):
        self.inputs[0].host = img
        self.context.active_optimization_profile = 0
        self.context.set_binding_shape(0, (self.batch_size, 3, img_h, img_w))
        # Transfer data from CPU to the GPU.
        [cuda.memcpy_htod_async(inp.device, inp.host, self.stream) for inp in self.inputs]
        # Run inference.
        self.context.execute_async(batch_size=self.batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
        # Transfer predictions back from the GPU.
        [cuda.memcpy_dtoh_async(out.host, out.device, self.stream) for out in self.outputs]
        # Synchronize the stream
        self.stream.synchronize()
        # Return only the host outputs.
        trt_outputs = [out.host for out in self.outputs]
            res = np.expand_dims(trt_outputs[0][:2], axis=0)
        else:
            confidences_shape, locations_shape = self.context.get_binding_shape(2), self.context.get_binding_shape(1)
            confidences = np.reshape(trt_outputs[1][:confidences_shape[0] * confidences_shape[1] * confidences_shape[2]], confidences_shape)
            locations = np.reshape(trt_outputs[0][:locations_shape[0] * locations_shape[1] * locations_shape[2]], locations_shape)
            res = (confidences, locations)
        return res
if __name__ == "__main__":
    model1 = TRTInference(path_to_engine1, "model1", batch_size=1)
    model2 = TRTInference(path_to_engine2, "model2", batch_size=1)
Some explanations:
class TRTInference is a public class to create two engines concurrently. I found that if I commented self.context = self.get_context() and self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers() in the __init__ of class TRTInference, it runs well.
And then I uncommented self.context = self.get_context(), segmentation fault shows up. So it seems like the two contexts may have some confict.
The code is just to pinpoint the problem. And if I use my own data to do the whole inference process, it can output the correct result but still throws a segmentation fault after outputting.
Traceback:
[TensorRT] WARNING: The logger passed into createInferRuntime differs from one already assigned, 0x557415842ea0, logger not updated.
[1] 4947 segmentation fault (core dumped) python detect.py
Please check the below link, as they might answer your concerns
I’ve gone through the doc you posted and did not find a solution from it. Could you elaborate please?
@751180903,
We are looking into this issue, meanwhile could you please share us error logs you got when you run this script and also if possible ONNX models to try from our for better debugging.
Thank you.
@spolisetty ,
Yes, the log seems ok. As i said, if i use some data to do the whole inference process(which means not only create engines and contexts but also call the do_inference method), it can output the correct result but still throws a segmentation fault after outputting.
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +263, GPU +0, now: CPU 321, GPU 246 (MiB)
[TensorRT] INFO: Loaded engine size: 2 MB
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 322 MiB, GPU 246 MiB
[TensorRT] VERBOSE: Using cublasLt a tactic source
[TensorRT] WARNING: TensorRT was linked against cuBLAS/cuBLAS LT 11.2.0 but loaded cuBLAS/cuBLAS LT 11.1.0
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +361, GPU +148, now: CPU 684, GPU 398 (MiB)
[TensorRT] VERBOSE: Using cuDNN as a tactic source
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +437, GPU +172, now: CPU 1121, GPU 570 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1121, GPU 552 (MiB)
[TensorRT] VERBOSE: Deserialization required 1063263 microseconds.
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine end: CPU 1121 MiB, GPU 552 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +1, GPU +10, now: CPU 1118, GPU 562 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 1118, GPU 570 (MiB)
[TensorRT] VERBOSE: Total per-runner device memory is 1677824
[TensorRT] VERBOSE: Total per-runner host memory is 33952
[TensorRT] VERBOSE: Allocated activation device memory of size 123759104
[TensorRT] WARNING: The logger passed into createInferRuntime differs from one already assigned, 0x559b37e5d380, logger not updated.
[TensorRT] INFO: [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 1125, GPU 690 (MiB)
[TensorRT] INFO: Loaded engine size: 3 MB
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine begin: CPU 1126 MiB, GPU 690 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +10, now: CPU 1126, GPU 704 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +1, GPU +10, now: CPU 1127, GPU 714 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1126, GPU 696 (MiB)
[TensorRT] VERBOSE: Deserialization required 15736 microseconds.
[TensorRT] INFO: [MemUsageSnapshot] deserializeCudaEngine end: CPU 1126 MiB, GPU 696 MiB
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +1, GPU +10, now: CPU 1126, GPU 706 (MiB)
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 1126, GPU 714 (MiB)
[TensorRT] VERBOSE: Total per-runner device memory is 2941952
[TensorRT] VERBOSE: Total per-runner host memory is 83888
[TensorRT] VERBOSE: Allocated activation device memory of size 7225344000
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1125, GPU 7594 (MiB)
[1]    31279 segmentation fault (core dumped)  python test.py
I
My onnx models:
model1.onnx (1.1 MB)
model2.onnx (2.6 MB)
Any updates? Thanks.
@751180903,
Please allow us sometime to work on this issue.
Thank you.
Hi
Any update? I have the same issue on:
t4
tensorrt :8
nvidia driver 460
cuda version 11.2
cudnn 9.1
python version 3.8
model yolov3
it works on AGX but not on t4.
Any updates?
any updates?
