Multiple tensorrt engine contexts for different models
Description
I want to have 5 models work together in a single stream.
Each model onnx file is separately loaded and parsed.
Each of the model contexts is created and kept in an array.
For contexts at 2,3,4(0-based indexing), The results are fine for every batch.
But for contexts 0,1. The results are garbage.
Environment
TensorRT Version: 8.0.1
GPU Type: 1050ti
Nvidia Driver Version: 470.82.01
CUDA Version: 11.4
CUDNN Version: NA
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.8
TensorFlow Version (if applicable): NA
PyTorch Version (if applicable): NA
Baremetal or Container (if container which image + tag): NA
Relevant Files
model_1.onnx (462.8 KB)
model_2.onnx (462.8 KB)
model_3.onnx (462.9 KB)
Steps To Reproduce
static IExecutionContext** colorContext;
colorContext = (IExecutionContext**)malloc(sizeof(IExecutionContext*) * NumColorModels );
static float* buffers_color[10];
int load_onnx(char *filename, char *enginename,  char* format, int isFP16){
  std::ifstream file(filename, std::ios::binary);
  spdlog::debug("Onnx path: {}", filename);
  spdlog::debug("TRT path: {}", enginename);
  if (!file.good()) {
    std::cerr << "ONNX read " << filename << " error!" << std::endl;
    return -1;
  IBuilder* builder = createInferBuilder(gLogger);
  if(strcmp(format, "NCHW") == 0){
    builder->setMaxBatchSize(BatchSize);
  else if (strncmp(format, "NF", 2) == 0) {
    builder->setMaxBatchSize(BatchSize * NumBodypart);
  uint32_t flag = 1U <<static_cast<uint32_t>
    (NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
  INetworkDefinition* network = builder->createNetworkV2(flag);
  IParser*  parser = createParser(*network, gLogger);
  parser->parseFromFile(filename, 3);
  for (int32_t i = 0; i < parser->getNbErrors(); ++i)
    std::cout << parser->getError(i)->desc() << std::endl;
  IOptimizationProfile* profile = builder->createOptimizationProfile();
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kMIN, Dims4(BatchSize,InputChannel,InputH,InputW));
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kOPT, Dims4(BatchSize,InputChannel,InputH,InputW));
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kMAX, Dims4(BatchSize,InputChannel,InputH,InputW));
    int featuresindex = atoi((&format[2])); // Starts from 0
    int featuresize = FeatureSizeList[featuresindex];
    spdlog::debug(" featuresize {} ", featuresize);
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kMIN, Dims2(BatchSize * NumBodypart,featuresize));
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kOPT, Dims2(BatchSize * NumBodypart,featuresize));
    profile->setDimensions(INPUT_BLOB_NAME, OptProfileSelector::kMAX, Dims2(BatchSize * NumBodypart,featuresize));
  IBuilderConfig* config = builder->createBuilderConfig();
  config->setMaxWorkspaceSize(1U << 20);
  config->addOptimizationProfile(profile);
  if(isFP16){
    config->setFlag(BuilderFlag::kFP16);
  IHostMemory*  serializedModel = builder->buildSerializedNetwork(*network, *config);
  std::ofstream p(enginename, std::ios::binary);
  if (!p) {
    std::cerr << "TRT engine could not open plan output file" << std::endl;
    return -1;
  p.write(reinterpret_cast<const char*>(serializedModel->data()), serializedModel->size());
  delete parser;
  delete network;
  delete config;
  delete builder;
  delete serializedModel;
  return 1;
int load_engine(char* filename, char* format){
  if (!file.good()) {
    std::cerr << "read " << filename << " error!" << std::endl;
    return -1;
  char *trtModelStream = nullptr;
  size_t size = 0;
  file.seekg(0, file.end);
  size = file.tellg();
  file.seekg(0, file.beg);
  trtModelStream = new char[size];
  assert(trtModelStream);
  file.read(trtModelStream, size);
  file.close();
  runtime = createInferRuntime(gLogger);
  assert(runtime != nullptr);
  engine = runtime->deserializeCudaEngine(trtModelStream, size);
  assert(engine != nullptr);
    context = engine->createExecutionContext();
    assert(context != nullptr);
    spdlog::debug(" featureindex : {} ", featuresindex);
    colorContext[featuresindex] = engine->createExecutionContext();
    assert(colorContext[featuresindex] != nullptr);
  delete[] trtModelStream;
  inputIndex = engine->getBindingIndex(INPUT_BLOB_NAME);
  outputIndex = engine->getBindingIndex(OUTPUT_BLOB_NAME);
  assert(inputIndex == 0);
  assert(outputIndex == 1);
  // Create GPU buffers on device
    CUDA_CHECK(cudaMalloc((void**)&buffers[inputIndex], BatchSize * InputChannel * InputH * InputW  * sizeof(float)));
    CUDA_CHECK(cudaMalloc((void**)&buffers[outputIndex],BatchSize * OutputChannel * InputH * InputW  * sizeof(float)));
    context->setBindingDimensions(inputIndex, Dims4(BatchSize, InputChannel, InputH, InputW));
    context->setOptimizationProfileAsync(0, stream);
    spdlog::debug("featureindex {}", featuresindex);
    spdlog::debug("featuresize {}", featuresize);
    spdlog::debug("BatchSize {}", BatchSize);
    spdlog::debug("NumBodypart {}", NumBodypart);
    spdlog::debug("NumColorClasses {}", NumColorClasses);
    CUDA_CHECK(cudaMalloc((void**)&buffers_color[2 * featuresindex + 0], BatchSize * NumBodypart * featuresize  * sizeof(float)));
    CUDA_CHECK(cudaMalloc((void**)&buffers_color[2 * featuresindex + 1], BatchSize * NumBodypart * NumColorClasses  * sizeof(float)));
    // std::cout << " CUDA pointer of buffers color allocated "<<  buffers_color[2 * featuresindex + 0] << "  "<< buffers_color[2 * featuresindex + 1];
    colorContext[featuresindex]->setBindingDimensions(inputIndex, Dims2(BatchSize * NumBodypart, featuresize));
    colorContext[featuresindex]->setOptimizationProfileAsync(0, stream);
  return 1;
// Works fine
void* colorBuffers1[] = { buffers_color[0], buffers_color[1] } ;
colorContext[2]->enqueue(currentBS * NumBodypart, (void**)colorBuffers1, stream, nullptr);
void* colorBuffers2[] = { buffers_color[2], buffers_color[3] } ;
colorContext[3]->enqueue(currentBS * NumBodypart, (void**)colorBuffers2, stream, nullptr);
void* colorBuffers3[] = { buffers_color[4], buffers_color[5] } ;
colorContext[4]->enqueue(currentBS * NumBodypart, (void**)colorBuffers3, stream, nullptr);
//Issues with results on different batchsizes.
void* colorBuffers4[] = { buffers_color[6], buffers_color[7] } ;
colorContext[0]->enqueue(currentBS * NumBodypart, (void**)colorBuffers4, stream, nullptr);
void* colorBuffers5[] = { buffers_color[8], buffers_color[9] } ;
colorContext[1]->enqueue(currentBS * NumBodypart, (void**)colorBuffers5, stream, nullptr);
The below links might be useful for you.
https://docs.nvidia.com/deeplearning/tensorrt/archives/tensorrt-803/best-practices/index.html#thread-safety
https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__STREAM.html
For multi-threading/streaming, will suggest you to use Deepstream or TRITON
For more details, we recommend you raise the query in the Deepstream forum.
or
raise the query in the Triton Inference Server Github instance issues section.
The issue was with ONNX model. It had multiple unnecessary outputs also. Once they were removed, the issue got resolved
