I am using the following docker file to build OpenCV from source on Jetson Xavier. However, I receive an error. Could you please let me know what changes do I need to make to get this running?
FROM jetson-cudnn8:latest
ARG DEBIAN_FRONTEND=noninteractive
# System update
RUN apt-get clean && apt-get update && apt-get install -y --no-install-recommends\
libgstreamer1.0-0 \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
gstreamer1.0-doc \
gstreamer1.0-tools \
libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev \
libdc1394-22-dev \
libavc1394-dev libavcodec-dev libavformat-dev libswscale-dev libavresample-dev \
libxvidcore-dev x264 libx264-dev libfaac-dev libmp3lame-dev libtheora-dev \
python3-pip \
&& rm -rf /var/lib/apt/lists/*
RUN update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.6 1
RUN update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.7 2
RUN update-alternatives --install /usr/bin/python python /usr/bin/python3 10
RUN pip3 install cython>=0.29.21 setuptools
RUN pip3 install --upgrade --force-reinstall numpy
RUN git clone https://github.com/opencv/opencv.git --branch 4.5.4 --single-branch && \
git clone https://github.com/opencv/opencv_contrib.git --branch 4.5.4 --single-branch && \
cd opencv && \
mkdir build && \
cd build && \
cmake -D CMAKE_BUILD_TYPE=Release -DOPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules/ -DBUILD_opencv_legacy=OFF \
-D CMAKE_C_COMPILER=gcc-7 -D CMAKE_CXX_COMPILER=g++-7\
-D CUDA_ARCH_BIN="5.3 6.2 7.2 7.5"\
-D CUDA_ARCH_PTX="5.3" \
-D CUDNN_VERSION="8.0" \
-D WITH_TBB=ON \
-D OPENCV_ENABLE_NONFREE=ON \
-D ENABLE_FAST_MATH=1 \
-D CUDA_FAST_MATH=1 \
-D WITH_CUDA=ON \
-D OPENCV_DNN_CUDA=ON \
-D WITH_CUBLAS=ON \
-D BUILD_EXAMPLES=OFF -D BUILD_opencv_apps=OFF -D BUILD_DOCS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_TESTS=OFF \
-D OPENCV_GENERATE_PKGCONFIG=ON \
-DCMAKE_INSTALL_PREFIX=/usr/local ../ && \
make -j $(nproc) && \
make install && \
rm -rf /opencv /opencv_contrib
RUN echo "/usr/local/lib" >> /etc/ld.so.conf.d/opencv.conf && ldconfig -v
RUN pip3 install wheel
# System update
build-essential \
cmake \
git \
wget \
unzip \
yasm \
pkg-config \
libtool \
nasm \
automake \
libpng-dev \
libjpeg-turbo8-dev \
libssl-dev \
liblapack-dev \
libatlas-base-dev \
python3.7 \
python3.7-dev \
python3-distutils \
libpython3-dev \
python3-pip \
python3-numpy \
libeigen3-dev \
libjpeg-dev \
python3-setuptools \
libxmu-dev \
libxi-dev \
python3-zmq \
python3-protobuf \
gnupg1 gnupg2 \
COPY ./trusted.gpg /etc/apt/
COPY ./jetson-ota-public.asc /etc/apt/trusted.gpg.d/
RUN apt-key add /etc/apt/trusted.gpg && apt-key add /etc/apt/trusted.gpg.d/jetson-ota-public.asc
COPY ./nvidia-l4t-apt-source.list /etc/apt/sources.list.d/
RUN apt-get clean && apt-get update && apt upgrade -y && apt-get install -y --no-install-recommends\
libcudnn8 \
libcudnn8-dev \
libcublas-dev \
cuda-cufft-dev-10-2 \
cuda-npp-dev-10-2 \
cuda-nvcc-10-2 \
libcublas-dev \
cuda-compiler-10-2 \
cuda-cudart-dev-10-2 \
cuda-cupti-dev-10-2 \
cuda-curand-dev-10-2 \
cuda-cusolver-dev-10-2 \
cuda-cusparse-dev-10-2 \
cuda-libraries-dev-10-2 \
cuda-misc-headers-10-2 \
cuda-nvml-dev-10-2
The error is:
---> Running in 5d507f5234b4
failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown
ERROR: Service 'opencv_python3.6' failed to build : Build failed```
