ERROR: Failed to enqueue trt inference batch in deepstream-app
Jetson
• DeepStream Version
6.0.1
• TensorRT Version
8.2.1-1+cuda10.2
Hi, I am trying to use a custom yolov7-tiny model as the primary detector in the deepstream-app. After training, I used this command (in the yolov7 directory) to export the model file to onnx.
sudo python3 export.py --weights ./best.pt --grid --end2end --simplify --topk-all 100 --iou-thres 0.65 --conf-thres 0.35 --img-size 640 640 --max-wh 640 --dynamic-batch
Here is the onnxfile generated : link
Now when I use this onnx file in the deepstream-app, it generates the engine file but while running the pipeline, it shows error like this:
Unknown or legacy key specified 'is-classifier' for group [property]
Unknown or legacy key specified 'disable-output-host-copy' for group [property]
Unknown or legacy key specified 'crop-objects-to-roi-boundary' for group [property]
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
0:00:06.955669204 18637   0x556595f040 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/yolov7_primary_detector/yolov7-tiny-new.onnx_b8_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 2
0   INPUT  kFLOAT images          3x640x640       min: 1x3x640x640     opt: 8x3x640x640     Max: 8x3x640x640
1   OUTPUT kFLOAT output          7               min: 0               opt: 0               Max: 0
0:00:06.957044334 18637   0x556595f040 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/yolov7_primary_detector/yolov7-tiny-new.onnx_b8_gpu0_fp16.engine
0:00:07.017783631 18637   0x556595f040 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/samples/models/yolov7_primary_detector/config_infer_primary_yoloV7.txt sucessfully
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF:  FPS 0 (Avg)
**PERF:  0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:180>: Pipeline running
ERROR: [TRT]: 1: [runner.cpp::execute::416] Error Code 1: Cuda Runtime (invalid argument)
ERROR: Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
0:00:09.273044487 18637   0x55654f1320 WARN                 nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
ERROR from primary_gie: Failed to queue input batch for inferencing
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1324): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
Quitting
0:00:09.330013194 18637   0x55654f1320 WARN                 nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
0:00:09.337557864 18637   0x55654f1320 WARN                 nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
0:00:09.345006335 18637   0x55654f1320 WARN                 nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
[NvMultiObjectTracker] De-initialized
0:00:14.583387358 18637   0x55654f1320 WARN                 nvinfer gstnvinfer.cpp:1324:gst_nvinfer_input_queue_loop:<primary_gie> error: Failed to queue input batch for inferencing
App run failed
any idea how to fix this?
  1. dose the model run fine using a third party tool?
  2. can you share the configuration file?
  1. I tested the .pt file of the trained model, it is running fine, don’t know about the onnx file. I have already provided the command I used to convert the .pt file to onnx.
  2. Here is the primary_detector configuration file
# SPDX-FileCopyrightText: Copyright (c) 2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: MIT
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
#   int8-calib-file(Only in INT8), model-file-format
#   Caffemodel mandatory properties: model-file, proto-file, output-blob-names
#   UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
#   ONNX: onnx-file
# Mandatory properties for detectors:
#   num-detected-classes
# Optional properties for detectors:
#   cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
#   custom-lib-path
#   parse-bbox-func-name
# Mandatory properties for classifiers:
#   classifier-threshold, is-classifier
# Optional properties for classifiers:
#   classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
#   operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
#   input-object-min-width, input-object-min-height, input-object-max-width,
#   input-object-max-height
# Following properties are always recommended:
#   batch-size(Default=1)
# Other optional properties:
#   net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
#   model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
#   mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
#   custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#0=RGB, 1=BGR
model-color-format=0
onnx-file=yolov7-tiny-new.onnx
model-engine-file=yolov7-tiny-new.onnx_b8_gpu0_fp16.engine
labelfile-path=labels.txt
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=7
gie-unique-id=1
network-type=0
is-classifier=0
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
## Bilinear Interpolation
scaling-filter=1
#parse-bbox-func-name=NvDsInferParseCustomYoloV7
parse-bbox-func-name=NvDsInferParseCustomYoloV7_cuda
#disable-output-host-copy=0
disable-output-host-copy=1
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.0/sources/libs/nvdsinfer_customparser_yolo/libnvdsinfer_custom_impl_Yolo.so
#scaling-compute-hw=0
## start from DS6.2
crop-objects-to-roi-boundary=1
[class-attrs-all]
#nms-iou-threshold=0.3
#threshold=0.7
nms-iou-threshold=0.65
pre-cluster-threshold=0.25
topk=300
and here is the configurations file for the deepstream-app
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=4
batch-size=8
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
labelfile-path=/opt/nvidia/deepstream/deepstream/samples/models/yolov7_primary_detector/labels.txt
#model-engine-file=/opt/nvidia/deepstream/deepstream/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_fp16.engine
batch-size=8
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
#config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt
config-file=/opt/nvidia/deepstream/deepstream/samples/models/yolov7_primary_detector/config_infer_primary_yoloV7.txt
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=config_tracker_IOU.yml
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=config_tracker_NvDCF_accuracy.yml
# ll-config-file=config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[secondary-gie0]
enable=0
model-engine-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=0
model-engine-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt
[secondary-gie2]
enable=0
model-engine-file=/opt/nvidia/deepstream/deepstream/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine
batch-size=16
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_carmake.txt
[tests]
file-loop=0
[nvds-analytics]
enable=1
config-file=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-nvdsanalytics-test/config_nvdsanalytics.txt
I can’t reproduce the same issue on Orin+DS6.2, here are the configuration file and log.
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_new.txt (5.7 KB)
config_infer_primary-new.txt (3.8 KB)
log.txt (101.3 KB)
can you check if the libs version meet the requirements? Compatibility
Hi, thanks for the reply. If it is possible, could you please test the model on ds 6.0.1? that way we can confirm that there is some compatibility issue. Thanks.
sorry, On Jetson we only focus on the latest 6.2 version, I suggest to test other samples like test1 to narrow this issue.
