When I use Sage Attention3 in HunyuanVideo, the following error occurs:
My device is DGX Spark GB10.
!!!!!!!!!!!!!!!!!!!!!!!!Use Sage Attention!!!!!!!!!!!!!!!!!!!!!!!!
q.shape: torch.Size([1, 24, 119056, 128]) torch.bfloat16
k.shape: torch.Size([1, 24, 119056, 128]) torch.bfloat16
v.shape: torch.Size([1, 24, 119056, 128]) torch.bfloat16
TMA Desc Addr: 0xffffeda9e500
format 7
dim 5
gmem_address 0xe76400000000
globalDim (128,931,931,24,1)
globalStrides (4,476672,512,443781632,2305843002684583936)
boxDim (128,1,1,1,1)
elementStrides (1,1,1,1,1)
interleave 0
swizzle 0
l2Promotion 2
oobFill 0
Error: Failed to initialize the TMA descriptor 1
!!!!!!!!!!!!!!!!!!!!!!!!Sage Attention Done!!!!!!!!!!!!!!!!!!!!!!!!
0%| | 0/50 [00:05<?, ?it/s]
File "/home/vincent/Desktop/l00906346/HunyuanVideo/sample_video.py", line 87, in <module>
main()
File "/home/vincent/Desktop/l00906346/HunyuanVideo/sample_video.py", line 61, in main
outputs = hunyuan_video_sampler.predict(
File "/home/vincent/miniconda3/envs/wan2.1_lx/lib/python3.12/site-packages/torch/utils/_contextlib.py", line 120, in decorate_context
return func(*args, **kwargs)
File "/home/vincent/Desktop/l00906346/HunyuanVideo/hyvideo/inference.py", line 648, in predict
samples = self.pipeline(
File "/home/vincent/Desktop/l00906346/HunyuanVideo/hyvideo/diffusion/pipelines/pipeline_hunyuan_video.py", line 991, in __call__
noise_pred = self.transformer( # For an input image (129, 192, 336) (1, 256, 256)
File "/home/vincent/miniconda3/envs/wan2.1_lx/lib/python3.12/site-packages/torch/nn/modules/module.py", line 1775, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File "/home/vincent/miniconda3/envs/wan2.1_lx/lib/python3.12/site-packages/torch/nn/modules/module.py", line 1786, in _call_impl
return forward_call(*args, **kwargs)
File "/home/vincent/Desktop/l00906346/HunyuanVideo/hyvideo/modules/models.py", line 667, in forward
img, txt = block(*double_block_args)
File "/home/vincent/Desktop/l00906346/HunyuanVideo/hyvideo/modules/models.py", line 233, in forward
self.img_mlp(
File "/home/vincent/Desktop/l00906346/HunyuanVideo/hyvideo/modules/mlp_layers.py", line 54, in forward
x = self.act(x)
File "/home/vincent/miniconda3/envs/wan2.1_lx/lib/python3.12/site-packages/torch/nn/modules/activation.py", line 816, in forward
return F.gelu(input, approximate=self.approximate)
torch.AcceleratorError: CUDA error: an illegal instruction was encountered
Search for `cudaErrorIllegalInstruction' in https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__TYPES.html for more information.
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1
Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
This error only appears with specific shapes, such as 720p x 1280p x 129f.
It works fine when I use the 544p x 960p x 129f specification for generation.
