ERROR from element encoder-5: Could not get/set settings from/on resource
my code can run 5 resource, but i got this error when i run 6 resource. i do not know why .
ERROR from element encoder-5: Could not get/set settings from/on resource.
Error details: gstv4l2object.c(3511): gst_v4l2_object_set_format_full (): /GstPipeline:ds-multi-stream-pipeline-zxf/nvv4l2h264enc:encoder-5:
Device is in streaming mode
• DeepStream Version
• TensorRT Version
• The pipeline being used
If you use dGPU, you can check the limit on the number of encoder instances from this table
