Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
I have plugged in my camera and followed tutorials but I keep receiving the error: “Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available”
Any ideas of how to fix this?
I am on a Jetson Nano B01 & I have tried switching the source camera.
I am currently using an inland 5mp camera.
Did you integrate your sensor driver to the system?
Have a check below doc for the customized kernel and sensor programing guide.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fcamera_sensor_prog.html%23
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html%23
Hey, I’m having the same problem but I couldn’t get exactly what to do. Can you explain me, please? Thank you.
@furkan.nargul
What’s your sensor? You need integrate correct driver for using it.
My camera is Arducam IMX219.
I would suggest consult with Arducam to get the driver to integrate it.
I’m using a Raspberry Pi v2.1 IMX219 camera module and I have the same error. Any suggestions?
@TTNprog
Check if the device probe correctly. Maybe your cable didn’t connect correctly
v4l2-ctl --list-devices
dmesg | grep -i imx219
Hello there!
After digging through various answers and solutions it turns out that:
I needed a genuine Raspberry Pi imx219 camera &
used this command:
sudo dpkg -r arducam-nvidia-l4t-kernel
Then my week long issue was resolved. Thank you!
