• Hardware Platform GPU
**• DeepStream Version 5.0 **
• TensorRT Version 7.0
• NVIDIA GPU Driver Version 440
root@b56f06c32064:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app# deepstream-app -c config_infer_primary.txt
I ran the above command inside the deepstream 5.0 container and got the below error.
**(deepstream-app:72): GStreamer-CRITICAL : 15:05:28.928: gst_element_get_static_pad: assertion ‘GST_IS_ELEMENT (element)’ failed
In fact I tried running all the config files present inside samples/configs and I got the same error.
