I have a problem with calculations on unsigned char arguments. I was able to write a small example to reproduce it.
The code below allocates 3 values of INPUT_TYPE (unsigned chars of unsigned ints, depending on the define), copies them to the device, calculates the result on the device, reads back the result, and executes the same function on the host. When abc[2] != 0, and INPUT_TYPE is unsigned char, the results are different, and the result I get from the device is wrong.
If I compile the code with
-deviceemu
the results are correct.
if I compile the code with INPUT_TYPE = unsigned int, the result is also correct.
I added the readback of the casted arguments abc, and they are always correct (as seen in the output).
When looking at the generated ptx files in both cases (chars and ints), the only difference there is, is when loading the arguments, the former uses ld.global.u8, while the latter uses ld.global.s32 (which is correct, since I cast the values to int).
Program:
#include <stdio.h>
#include <cutil.h>
#define INPUT_TYPE unsigned char
//#define INPUT_TYPE unsigned int
__device__ __host__ int calc(int a, int b, int c) {
return 28784 * a - 24103 * b - 4681 * c;
__global__ void kernel(const void* iData, void* oData) {
const INPUT_TYPE *iPtr = ( const INPUT_TYPE * )iData;
int *oPtr = (int*)oData;
int a = (int)(unsigned)iPtr[0];
int b = (int)(unsigned)iPtr[1];
int c = (int)(unsigned)iPtr[2];
int res = calc(a, b, c);
oPtr[0] = res;
// testing cast
oPtr[1] = a;
oPtr[2] = b;
oPtr[3] = c;
int main() {
INPUT_TYPE abc[3] = {0, 0, 1};
void* iDataGPU;
CUDA_SAFE_CALL(cudaMalloc(&iDataGPU, 3*sizeof(INPUT_TYPE)));
CUDA_SAFE_CALL(cudaMemcpy(iDataGPU, abc, 3*sizeof(INPUT_TYPE), cudaMemcpyHostToDevice));
void* oDataGPU;
CUDA_SAFE_CALL(cudaMalloc(&oDataGPU, 4*sizeof(int)));
kernel<<< dim3(1), dim3(1)>>>(iDataGPU, oDataGPU);
CUDA_SAFE_CALL(cudaGetLastError());
int res;
CUDA_SAFE_CALL(cudaMemcpy(&res, oDataGPU, sizeof(int), cudaMemcpyDeviceToHost));
int abcout[3];
CUDA_SAFE_CALL(cudaMemcpy(abcout, (int*)oDataGPU + 1, 3*sizeof(int), cudaMemcpyDeviceToHost));
CUDA_SAFE_CALL(cudaFree(oDataGPU));
CUDA_SAFE_CALL(cudaFree(iDataGPU));
int swRes = calc(abc[0], abc[1], abc[2]);
printf("abc=[%d,%d,%d]; abcout=[%d,%d,%d], res=%d, swRes=%d\n", abc[0], abc[1], abc[2], abcout[0], abcout[1], abcout[2], res, swRes);
return 0;
Output:
abc=[0,0,1]; abcout=[0,0,1], res=306769335, swRes=-4681
Info:
> nvcc --version
Copyright (c) 2005-2006 NVIDIA Corporation
Built on Wed_Jun_20_18:50:03_PDT_2007
Cuda compilation tools, release 1.0, V0.2.1221
# CUDA SDK 10 Linux Version 1.00.0625.0025
> gcc -v
Using built-in specs.
Target: i686-pc-linux-gnu
Configured with: /var/tmp/portage/sys-devel/gcc-4.1.2/work/gcc-4.1.2/configure --prefix=/usr --bindir=/usr/i686-pc-linux-gnu/gcc-bin/4.1.2 --includedir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/include --datadir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2 --mandir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2/man --infodir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2/info --with-gxx-include-dir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/include/g++-v4 --host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --disable-altivec --enable-nls --without-included-gettext --with-system-zlib --disable-checking --disable-werror --enable-secureplt --disable-libunwind-exceptions --disable-multilib --enable-libmudflap --disable-libssp --disable-libgcj --enable-languages=c,c++,fortran --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu
Thread model: posix
gcc version 4.1.2 (Gentoo 4.1.2)
Installed video card: G80 (GeForce 8800 GTX rev a2)
Installed memory: 2GB
Processor type: Intel Core2 6300 @ 1.86GHz
Chipset: nVidia MCP55
