I created an SSD-Mobilenet Object Detection Model using PyTorch and the Open Images dataset.after that it was converted into ONNX and then into PB, when trying to convert to FF gives this error.
I also tried it with another model already trained in tensorflow and it gives the same error, the example models I can run normal.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
well, so far I haven’t been able to convert the PB model into FF and later to bin tensorRT enginem, but instead I took the ONNX model and managed to convert it into .engine tensor RT.
I wanted the model in bin because there are several examples of code in python, would you have any example of python code using the .engine model with the webcam?
