Error converting tf saved_model to trt
Description
Following Blog
Environment
TensorRT Version: 7.2.2
Nvidia Driver Version: 460
CUDA Version: 11.2
Operating System + Version: Ubuntu 18.04
Python Version: 3.6
TensorFlow Version: 2.5
My .pb saved model info
$ saved_model_cli show --dir ../saved_model/ --tag_set serve --signature_def serving_default
The given SavedModel SignatureDef contains the following input(s):
  inputs['input_tensor'] tensor_info:
      dtype: DT_UINT8
      shape: (1, -1, -1, 3)
The given SavedModel SignatureDef contains the following output(s):
  outputs['detection_anchor_indices'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 100)
  outputs['detection_boxes'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 100, 4)
  outputs['detection_classes'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 100)
  outputs['detection_multiclass_scores'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 100, 3)
  outputs['detection_scores'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 100)
  outputs['num_detections'] tensor_info:
      dtype: DT_FLOAT
      shape: (1)
  outputs['raw_detection_boxes'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 49104, 4)
  outputs['raw_detection_scores'] tensor_info:
      dtype: DT_FLOAT
      shape: (1, 49104, 3)
Method name is: tensorflow/serving/predict
(Considering above SavedModel SignatureDef of saved_model.pb)
So what should be the tf2onnx.convert command?
somewhat like this..?
python3 -m tf2onnx.convert  --input ../saved_model.pb --inputs serving_default_input_tensor:0 --outputs StatefulPartitionedCall:7 --output model.onnx
Hi @skim1,
Please refer following,
Thank you.
      dtype: DT_UINT8
@spolisetty is it look like invalid shape?
Hi @skim1,
Looks like you’re using UINT8 data type. UINT8 is not supported by TensorRT. Please fix this.
Please share us ONNX model if you face any further issues.
Thank you.
