Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 7.2.3
GPU Type: GeForce GTX 1050 Ti
Nvidia Driver Version: 465
CUDA Version: 11.2
CUDNN Version: 8…*
Operating System + Version: ubuntu 18.04
Python Version (if applicable): 3.6
**TensorFlow Version (if applicable)**2.6:
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
I have tensorflow segmentation model with deeplabv3 (axial_swidernet_1_1_3_os16_axial_deeplab_cityscapes_trainfine_saved_mode) I am trying to convert this tensorlow model to tensorrt .
But I am getting following errors while converting this model
tyTraceback (most recent call last):
File "convert.py", line 10, in <module>
converter.convert()
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/compiler/tensorrt/trt_convert.py", line 1099, in convert
frozen_func = convert_to_constants.convert_variables_to_constants_v2(func)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/framework/convert_to_constants.py", line 1154, in convert_variables_to_constants_v2
converted_input_indices)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/framework/convert_to_constants.py", line 1080, in _construct_concrete_function
new_output_names)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/eager/wrap_function.py", line 650, in function_from_graph_def
wrapped_import = wrap_function(_imports_graph_def, [])
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/eager/wrap_function.py", line 628, in wrap_function
collections={}),
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/framework/func_graph.py", line 1007, in func_graph_from_py_func
func_outputs = python_func(*func_args, **func_kwargs)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/eager/wrap_function.py", line 87, in __call__
return self.call_with_variable_creator_scope(self._fn)(*args, **kwargs)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/eager/wrap_function.py", line 93, in wrapped
return fn(*args, **kwargs)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/eager/wrap_function.py", line 648, in _imports_graph_def
importer.import_graph_def(graph_def, name="")
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/util/deprecation.py", line 549, in new_func
return func(*args, **kwargs)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/framework/importer.py", line 405, in import_graph_def
producer_op_list=producer_op_list)
File "/home/admin1/.virtualenvs/list/lib/python3.6/site-packages/tensorflow/python/framework/importer.py", line 501, in _import_graph_def_internal
raise ValueError(str(e))
ValueError: Node 'StatefulPartitionedCall/DeepLab/axial_swidernet/stage4/block2/attention/height_axis/query_rpe/Gather/axis' is not unique
pe or paste code here
Relevant Files
Steps To Reproduce
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
conversion_params = conversion_params._replace(precision_mode="FP16")
converter = trt.TrtGraphConverterV2(
input_saved_model_dir=input_saved_model_dir,
conversion_params=conversion_params)
converter.convert()
def my_input_fn():
# Input for a single inference call, for a network that has two input tensors:
Inp1 = np.random.normal(size=(8, 16, 16, 3)).astype(np.float32)
inp2 = np.random.normal(size=(8, 16, 16, 3)).astype(np.float32)
yield (inp1, inp2)
converter.build(input_fn=my_input_fn)
converter.save(output_saved_model_dir)
saved_model_loaded = tf.saved_model.load(
output_saved_model_dir, tags=[tag_constants.SERVING])
graph_func = saved_model_loaded.signatures[
signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
output = graph_func(input_data)[0].numpy()
