Error in export a DetectNet_v2 model in INT8 mode
Hello, I tried to export a DetectNet_v2 model in INT8 mode to get calibration.bin
but I got this error:
!tlt-export $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/resnet18_detector.tlt \
            -o $USER_EXPERIMENT_DIR/experiment_dir_final/resnet18_detector_INT8.etlt \
            --outputs output_cov/Sigmoid,output_bbox/BiasAdd \
            -k $KEY \
            --input_dims 3,720,1280 \
            --max_workspace_size 1100000 \
            --export_module detectnet_v2 \
            --cal_data_file $USER_EXPERIMENT_DIR/experiment_dir_final/calibration.tensor \
            --data_type int8 \
            --batches 10 \
            --cal_cache_file $USER_EXPERIMENT_DIR/experiment_dir_final/calibration.bin \
            --cal_batch_size 4 \
            --verbose
Using TensorFlow backend.
2019-11-27 11:13:41,293 [INFO] iva.common.magnet_export: Loading model from /workspace/tlt-experiments/experiment_dir_unpruned/weights/resnet18_detector.tlt
2019-11-27 11:13:41.294458: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-11-27 11:13:41.338340: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-11-27 11:13:41.338832: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x5f9ce60 executing computations on platform CUDA. Devices:
2019-11-27 11:13:41.338857: I tensorflow/compiler/xla/service/service.cc:158]   StreamExecutor device (0): GeForce GTX 950M, Compute Capability 5.0
2019-11-27 11:13:41.359972: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2593905000 Hz
2019-11-27 11:13:41.361109: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x6460fd0 executing computations on platform Host. Devices:
2019-11-27 11:13:41.361142: I tensorflow/compiler/xla/service/service.cc:158]   StreamExecutor device (0): <undefined>, <undefined>
2019-11-27 11:13:41.361341: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: GeForce GTX 950M major: 5 minor: 0 memoryClockRate(GHz): 1.124
pciBusID: 0000:0a:00.0
totalMemory: 3.95GiB freeMemory: 3.69GiB
2019-11-27 11:13:41.361372: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-27 11:13:41.520957: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-27 11:13:41.521002: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990]      0
2019-11-27 11:13:41.521012: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0:   N
2019-11-27 11:13:41.521151: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 3448 MB memory) -> physical GPU (device: 0, name: GeForce GTX 950M, pci bus id: 0000:0a:00.0, compute capability: 5.0)
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py:263: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Instructions for updating:
Colocations handled automatically by placer.
2019-11-27 11:13:48,201 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py:263: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
2019-11-27 11:14:05.070637: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-27 11:14:05.070736: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-27 11:14:05.070775: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990]      0
2019-11-27 11:14:05.070790: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0:   N
2019-11-27 11:14:05.070916: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 3448 MB memory) -> physical GPU (device: 0, name: GeForce GTX 950M, pci bus id: 0000:0a:00.0, compute capability: 5.0)
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:249: __init__ (from tensorflow.python.platform.gfile) is deprecated and will be removed in a future version.
Use tf.gfile.GFile.
2019-11-27 11:14:07,686 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:249: __init__ (from tensorflow.python.platform.gfile) is deprecated and will be removed in a future version.
Use tf.gfile.GFile.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:127: checkpoint_exists (from tensorflow.python.training.checkpoint_management) is deprecated and will be removed in a future version.
Use standard file APIs to check for files with this prefix.
2019-11-27 11:14:08,725 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:127: checkpoint_exists (from tensorflow.python.training.checkpoint_management) is deprecated and will be removed in a future version.
2019-11-27 11:14:09.033192: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-27 11:14:09.033272: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-27 11:14:09.033296: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990]      0
2019-11-27 11:14:09.033316: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0:   N
2019-11-27 11:14:09.033405: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 3448 MB memory) -> physical GPU (device: 0, name: GeForce GTX 950M, pci bus id: 0000:0a:00.0, compute capability: 5.0)
INFO:tensorflow:Restoring parameters from /tmp/tmpPkudrd.ckpt
2019-11-27 11:14:09,179 [INFO] tensorflow: Restoring parameters from /tmp/tmpPkudrd.ckpt
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:232: convert_variables_to_constants (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use tf.compat.v1.graph_util.convert_variables_to_constants
2019-11-27 11:14:09,434 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/tools/freeze_graph.py:232: convert_variables_to_constants (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/graph_util_impl.py:245: extract_sub_graph (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use tf.compat.v1.graph_util.extract_sub_graph
2019-11-27 11:14:09,435 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/graph_util_impl.py:245: extract_sub_graph (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
INFO:tensorflow:Froze 130 variables.
2019-11-27 11:14:09,554 [INFO] tensorflow: Froze 130 variables.
INFO:tensorflow:Converted 130 variables to const ops.
2019-11-27 11:14:09,600 [INFO] tensorflow: Converted 130 variables to const ops.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
2019-11-27 11:14:40,368 [INFO] iva.common.magnet_export: Calibrating the exported model. Please don't panic as this may take a while.
2019-11-27 11:14:40,368 [ERROR] modulus.export._tensorrt: Specified INT8 but not supported on platform.
  File "/usr/local/bin/tlt-export", line 10, in <module>
    sys.exit(main())
  File "./common/magnet_export.py", line 206, in main
  File "./common/magnet_export.py", line 491, in magnet_export
  File "./modulus/export/_tensorrt.py", line 515, in __init__
  File "./modulus/export/_tensorrt.py", line 385, in __init__
AttributeError: Specified INT8 but not supported on platform.
here is my tlt-export code
            -k $KEY \
            --data_type int8 \
            --batches 10 \
            --verbose
Hi m.billson16,
You are running with GTX950M according to the log.
But unfortunately the GTX950M can not support INT8 operation.
Its CUDA Compute Capability is 5.0
Hello Morganh, Thank you very much for your help.
So can I still deploy tlt-converter for deepstream? Since in the guide, we need INT8 to generate calibration.bin to run tlt-converter. Do you have any idea? Should I downgrade my NVIDIA GPU Drivers?
Can you try other precision mode(fp16 or fp32)? Please refer to the process in https://devtalk.nvidia.com/default/topic/1065558/transfer-learning-toolkit/trt-engine-deployment/
Hello Morganh, I have want to try another precision mode, like fp16. But when I run tlt-converter on my laptop. I got this error
[ERROR] runtime.cpp (25) - Cuda Error in allocate: 2 (out of memory)
[ERROR] Unable to create engine
this is my tlt-converter code
!tlt-converter $USER_EXPERIMENT_DIR/experiment_dir_final/resnet18_detector.etlt \
               -k $KEY \
               -o output_cov/Sigmoid,output_bbox/BiasAdd \
               -d 3,720,1280 \
               -i nchw \
               -m 64 \
               -t fp16 \
               -e $USER_EXPERIMENT_DIR/experiment_dir_final/resnet18_detector.engine \
Firstly, please check below requirements of TLT according to Integrating TAO Models into DeepStream — TAO Toolkit 3.22.05 documentation
Hardware Requirements
Minimum
4 GB system RAM
4 GB of GPU RAM
Single core CPU
1 GPU
50 GB of HDD space
Recommended
32 GB system RAM
32 GB of GPU RAM
8 core CPU
4 GPUs
100 GB of SSD space
Software Requirements
Ubuntu 18.04 LTS
NVIDIA GPU Cloud account and API key - https://ngc.nvidia.com/
docker-ce installed, Install Docker Engine on Ubuntu | Docker Documentation
nvidia-docker2 installed, instructions: Installation (version 2.0) · NVIDIA/nvidia-docker Wiki · GitHub
NVIDIA GPU driver v410.xx or above
Note: DeepStream 4.0 - NVIDIA SDK for IVA inference https://developer.nvidia.com/deepstream-sdk is recommended.
More, you can try to add “-w” argument into command line. For example, add " -w 50000000 " in the end.
Below is the help of tlt-converter.
$ ./tlt-converter -h
usage: ./tlt-converter [-h] [-v] [-e ENGINE_FILE_PATH]
        [-k ENCODE_KEY] [-c CACHE_FILE]
        [-o OUTPUTS] [-d INPUT_DIMENSIONS]
        [-b BATCH_SIZE] [-m MAX_BATCH_SIZE]
        [-w MAX_WORKSPACE_SIZE] [-t DATA_TYPE]
        [-i INPUT_ORDER]
        input_file
Generate TensorRT engine from exported model
positional arguments:
  input_file            Input file (.etlt exported model).
required flag arguments:
  -d            comma separated list of input dimensions
  -k            model encoding key
optional flag arguments:
  -b            calibration batch size (default 8)
  -c            calibration cache file (default cal.bin)
  -e            file the engine is saved to (default saved.engine)
  -i            input dimension ordering -- nchw, nhwc, nc (default nchw)
  -m            maximum TensorRT engine batch size (default 16)
  -o            comma separated list of output node names (default none)
  -t            TensorRT data type -- fp32, fp16, int8 (default fp32)
  -w            maximum workspace size of TensorRT engine (default 1<<30)
I also have the original issue:
2020-09-23 08:51:26.633200: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:30.285351: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-09-23 08:51:30.285616: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:30.286311: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: Tesla P100-PCIE-16GB major: 6 minor: 0 memoryClockRate(GHz): 1.3285
pciBusID: 0000:00:04.0
2020-09-23 08:51:30.286347: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:30.286405: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-23 08:51:30.288083: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-23 08:51:30.288180: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-23 08:51:30.290270: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-23 08:51:30.292446: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-23 08:51:30.292570: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-23 08:51:30.292742: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:30.293500: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:30.294110: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-23 08:51:30.294161: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:31.215543: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-23 08:51:31.215601: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-23 08:51:31.215620: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-23 08:51:31.215878: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:31.216597: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:31.217281: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:31.217940: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 14649 MB memory) -> physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
2020-09-23 08:51:36.679384: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:36.680205: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-23 08:51:36.680286: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:36.680365: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-23 08:51:36.680388: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-23 08:51:36.680409: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-23 08:51:36.680429: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-23 08:51:36.680449: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-23 08:51:36.680469: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-23 08:51:36.680590: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:36.681309: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:36.681962: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-23 08:51:36.682012: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-23 08:51:36.682026: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-23 08:51:36.682060: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-23 08:51:36.682182: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:36.682920: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:36.683519: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 14649 MB memory) -> physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
2020-09-23 08:51:39,975 [DEBUG] iva.common.export.base_exporter: Saving etlt model file at: /workspace/tlt-experiments/classification/export/final_model.etlt.
2020-09-23 08:51:43,403 [DEBUG] modulus.export._uff: Patching keras BatchNormalization...
2020-09-23 08:51:43,404 [DEBUG] modulus.export._uff: Patching keras Dropout...
2020-09-23 08:51:43,404 [DEBUG] modulus.export._uff: Patching UFF TensorFlow converter apply_fused_padding...
2020-09-23 08:51:44.491266: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:44.491965: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-23 08:51:44.492020: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:44.492074: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-23 08:51:44.492099: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-23 08:51:44.492119: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-23 08:51:44.492139: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-23 08:51:44.492159: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-23 08:51:44.492179: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-23 08:51:44.492274: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:44.492927: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:44.493513: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-23 08:51:44.493551: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-23 08:51:44.493565: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-23 08:51:44.493573: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-23 08:51:44.493679: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:44.494327: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:44.494892: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 14649 MB memory) -> physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
2020-09-23 08:51:44,982 [DEBUG] modulus.export._uff: Unpatching keras BatchNormalization layer...
2020-09-23 08:51:44,982 [DEBUG] modulus.export._uff: Unpatching keras Dropout layer...
2020-09-23 08:51:47.347804: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.348577: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-23 08:51:47.348681: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:47.348784: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-23 08:51:47.348816: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-23 08:51:47.348840: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-23 08:51:47.348876: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-23 08:51:47.348921: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-23 08:51:47.348962: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-23 08:51:47.349078: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.349887: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.350605: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-23 08:51:47.351039: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.351824: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-23 08:51:47.351878: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-23 08:51:47.351939: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-23 08:51:47.351973: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-23 08:51:47.351997: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-23 08:51:47.352020: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-23 08:51:47.352044: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-23 08:51:47.352068: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-23 08:51:47.352178: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.352989: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.353676: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-23 08:51:47.353750: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-23 08:51:47.353792: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-23 08:51:47.353813: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-23 08:51:47.353950: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.354775: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-23 08:51:47.355454: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 14649 MB memory) -> physical GPU (device: 0, name: Tesla P100-PCIE-16GB, pci bus id: 0000:00:04.0, compute capability: 6.0)
NOTE: UFF has been tested with TensorFlow 1.14.0.
DEBUG: convert reshape to flatten node
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['predictions/Softmax'] as outputs
2020-09-23 08:51:48,949 [DEBUG] iva.common.export.base_exporter: Reading input dims from tensorfile.
2020-09-23 08:51:48,949 [DEBUG] modulus.export.data: Opening /workspace/tlt-experiments/classification/export/calibration.tensor with mode=r
2020-09-23 08:51:49,201 [DEBUG] iva.common.export.base_exporter: Input dims: (3, 224, 224)
2020-09-23 08:51:49,225 [DEBUG] modulus.export.data: Opening /workspace/tlt-experiments/classification/export/calibration.tensor with mode=r
2020-09-23 08:51:49,226 [INFO] iva.common.export.base_exporter: Calibration takes time especially if number of batches is large.
2020-09-23 08:51:49,227 [ERROR] modulus.export._tensorrt: Specified INT8 but not supported on platform.
  File "/usr/local/bin/tlt-export", line 8, in <module>
    sys.exit(main())
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 185, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 263, in run_export
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/base_exporter.py", line 505, in export
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.py", line 676, in __init__
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.py", line 469, in __init__
Using and NVIDIA P100… I think V100 is the only supported platform for INT8 quantification, as stated in the requirements.
V100 is not the only platform supporting int8.
Please see https://developer.nvidia.com/cuda-gpus#compute and Support Matrix :: NVIDIA Deep Learning TensorRT Documentation
