Error in NvDsInferContextImpl::parseBoundingBox()
First I trained a dssd-resnet50 object detection model on nvcr.io/nvidia/tlt-streamanalytics:v3.0-dp-py3
and then I used tao-converter to generate the engine file, but when I used deepstream-app to run When this file is used, deepstream-app reports an error
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4        **PERF:  FPS 0 (Avg)    FPS 1 (Avg)        **PERF:  0.00 (0.00)    0.00 (0.00)        **PERF:  0.00 (0.00)    0.00 (0.00)        **PERF:  0.00 (0.00)    0.00 (0.00)        **PERF:  0.00 (0.00)    0.00 (0.00)        **PERF:  0.00 (0.00)    0.00 (0.00)
0:00:40.034610171 29666      0x16c92a0 ERROR  nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]:
Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:00:40.034675482 29666      0x16c92a0 ERROR                nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]:
Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
• DeepStream Version
• TensorRT Version
• The pipeline being used
• Hardware Platform Jetson
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.4
• NVIDIA GPU Driver Version (valid for GPU only) cudnn 8.2.3.49
• Issue Type questions
• How to reproduce the issue ? First I trained a dssd-resnet50 object detection model on nvcr.io/nvidia/tlt-streamanalytics:v3.0-dp-py3
dssd_config_infer_primary.txt (3.4 KB)
dssd_Engine.txt (4.6 KB)
Please use dssd config file in deepstream_tao_apps/configs/dssd_tao at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
Thank you, the problem has been solved
