Jetson
• DeepStream Version
5.0
4.5
• TensorRT Version
7.1.3
questions
Train the tao instance segmentation using the coco dataset
• Requirement details( This is for the new requirement. Including the module name-for which plugin or for which sample application, the function description)
I trained Instance Segmentation using TAO MaskRCNN with all default parameters and using the coco dataset. I deployed the etlt model and tried to replace the engine with the default engine on deepstream folders, The original engine file generated the pipeline but the tao trained model with coco data set is generating the following error:
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
**PERF: 0.00 (0.00)
ERROR: some layers missing or unsupported data types in output tensors
0:03:24.795478726 12324 0x3fb77720 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:682> [UID = 1]: Failed to parse bboxes and instance mask using custom parse function
Segmentation fault
here is my config file
[property]
gpu-id=0
net-scale-factor=0.017507
offsets=123.675;116.280;103.53
model-color-format=0
#labelfile-path=mrcnn_labels_original.txt
labelfile-path=mrcnn_labels.txt
#tlt-encoded-model=../../models/tlt_pretrained_models/mrcnn/mask_rcnn_resnet50.etlt
#tlt-encoded-model=/opt/nvidia/deepstream/deepstream-5.0/samples/models/models/mrcnn/models/mrcnn/mask_rcnn_resnet50.etlt
tlt-encoded-model=/opt/nvidia/deepstream/deepstream-5.0/samples/models/models/mrcnn/amVisionModel/model.step-25000.etlt
#tlt-model-key=nvidia_tlt
tlt-model-key = NXVodTI0MXNnZGtzdXBic2o0cTIwbmp0bnA6N2IwZDEyMGYtMGZiOS00MDNlLTllOGMtOGMzOTJiYmRlMzk0
#model-engine-file=../../models/tlt_pretrained_models/mrcnn/mask_rcnn_resnet50.etlt_b1_gpu0_int8.engine
#model-engine-file=/opt/nvidia/deepstream/deepstream-5.0/samples/models/models/mrcnn/model.step-25000.engine
#int8-calib-file=/opt/nvidia/deepstream/deepstream-5.0/samples/models/models/mrcnn/models/mrcnn/cal.bin
#int8-calib-file=../../models/tlt_pretrained_models/mrcnn/cal.bin
infer-dims=3;832;1344;
uff-input-blob-name=Input
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=91
interval=0
gie-unique-id=1
network-type=3
#output-blob-names=generate_detections;mask_head/mask_fcn_logits/BiasAdd
output-blob-names=generate_detections;mask_fcn_logits/BiasAdd
parse-bbox-instance-mask-func-name=NvDsInferParseCustomMrcnnTLT
custom-lib-path=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_infercustomparser.so
#no cluster
## 0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
## MRCNN supports only cluster-mode=4; Clustering is done by the model itself
cluster-mode=4
workspace-size=1000
#segmentation-threshold=0.3
output-instance-mask=1
[class-attrs-all]
pre-cluster-threshold=0.8
#group-threshold=1
#eps=0.2
roi-top-offset=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
display-mask=1
display-bbox=0
display-text=0
[primary-gie]
enable=1
gpu-id=0
# Modify as necessary
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
# Replace the infer primary config file when you need to
# use other detection models
config-file=config_infer_primary_mrcnn.txt
The libnvds_infercustomparser.so
is on this directiory : /opt/nvidia/deepstream/deepstream-5.0/lib/
Regards
