Dmesg shows an error during kernel initialization. Will attach the relevant lines here. Btw, this same nvme ‘drive’ works just fine when installed in the host but the TX2 refuses to cooperate. Notice at 14.926.
[ 14.919363] iommu: Adding device 0000:00:01.0 to group 54
[ 14.919425] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 14.919528] pci 0000:01:00.0: [1b85:6018] type 00 class 0x010802
[ 14.919574] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 14.919775] iommu: Adding device 0000:01:00.0 to group 55
[ 14.924807] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 14.924889] pci 0000:00:01.0: BAR 8: assigned [mem 0x50100000-0x501fffff]
[ 14.924892] pci 0000:01:00.0: BAR 0: assigned [mem 0x50100000-0x50103fff 64bit]
[ 14.924907] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 14.924912] pci 0000:00:01.0: bridge window [mem 0x50100000-0x501fffff]
[ 14.924967] pcieport 0000:00:01.0: enabling device (0000 -> 0002)
[ 14.925039] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 14.925040] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 14.925044] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 14.925104] aer 0000:00:01.0:pcie02: service driver aer loaded
[ 14.925915] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 14.926097] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2 <<<-------------****
[ 15.079451] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 15.079462] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.079464] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.079467] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.079472] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.079474] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.079559] nvme 0000:01:00.0: Failed status: ffffffff, reset controller
[ 15.079565] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 15.079573] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.079576] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.079577] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.079582] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.079584] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.079586] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 15.079594] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.079596] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.079598] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.079602] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.079603] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.079639] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 15.079647] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.079649] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.079651] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.079659] nvme 0000:01:00.0: Cancelling I/O 1 QID 0
[ 15.079669] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.079670] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.079672] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.079689] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.079691] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.079692] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.079697] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.079698] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.079742] nvme 0000:01:00.0: Device failed to resume
[ 15.080748] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081623] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.081625] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.081627] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.081631] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.081633] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.081635] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081643] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.081645] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.081647] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.081651] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.081654] iommu: Removing device 0000:01:00.0 from group 55
[ 15.081655] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.081658] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081666] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.081668] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.081669] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.081673] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.081675] pcieport 0000:00:01.0: AER: Device recovery failed
[ 15.081677] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081685] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 15.081686] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 15.081688] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 15.081693] pcieport 0000:00:01.0: broadcast error_detected message
[ 15.081694] pcieport 0000:00:01.0: broadcast mmio_enabled message
[ 15.081696] pcieport 0000:00:01.0: broadcast resume message
[ 15.081699] pcieport 0000:00:01.0: AER: Device recovery successful
[ 15.081701] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081706] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081707] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081712] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081713] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081718] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081720] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081724] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081726] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081730] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081732] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081736] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081738] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081742] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081744] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081748] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081750] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081754] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081756] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081760] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081762] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081766] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081768] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081772] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081774] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081778] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081780] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081785] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081786] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081791] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081792] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081797] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081798] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081803] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081804] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081809] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081811] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081815] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081817] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081821] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081823] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081827] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081829] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081833] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081835] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081839] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081841] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081845] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081847] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081852] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081853] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081858] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081859] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081864] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081865] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081870] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081871] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081876] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081878] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081882] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081884] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081888] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081890] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081894] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081896] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081900] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081902] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081906] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081908] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081912] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081914] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081919] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081920] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081925] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081926] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081931] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081933] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081937] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081939] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081943] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081945] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081949] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081951] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081955] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081957] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081961] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081963] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081968] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081969] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081974] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081975] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081980] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081982] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081986] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081988] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081992] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.081994] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.081998] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082000] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082004] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082006] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082010] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082012] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082017] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082018] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082023] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082024] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082029] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082031] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082035] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082037] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082041] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082043] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082047] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082049] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082053] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082055] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082059] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082061] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082066] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082067] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082072] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082073] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082078] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082079] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082084] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082086] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082090] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082092] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082096] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082098] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082102] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082104] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082108] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082110] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082114] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082116] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082121] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082122] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082127] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082128] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082133] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082135] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082139] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082141] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082145] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082147] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082151] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082154] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082158] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082160] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082164] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082166] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082170] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082172] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082176] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082178] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082182] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082184] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082188] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082190] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082194] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082196] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082201] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082202] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082207] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082208] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082213] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082214] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082219] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082221] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082225] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082227] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082231] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082233] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082237] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082239] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082243] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082245] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082249] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.082251] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 15.082256] pcieport 0000:00:01.0: can't find device of ID0020
[ 15.604350] cfg80211: World regulatory domain updated:
[ 15.604354] cfg80211: DFS Master region: unset
[ 15.604355] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 15.604358] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
