ERROR: Input to reshape is a tensor with 2108 values, but the requested shape has 2074
• Hardware (RTX2070)
• Network Type (Yolo_v4_tiny)
• TLT Version ( 4.0.1)
I am trying to train yolo v4 model using TAO. My training images are 1920x1080 in resolution, thus I set the output_width: 1920
output_height: 1088
in the augmentation_config. My training config file is like bellow:
random_seed: 42
yolov4_config {
  big_anchor_shape: "[(260.69, 172.35), (125.91, 81.47), (72.27, 42.42)]"
  mid_anchor_shape: "[(30.80, 71.40), (38.97, 26.86), (18.88, 17.11)]"
  box_matching_iou: 0.25
  matching_neutral_box_iou: 0.5
  arch: "cspdarknet_tiny"
  loss_loc_weight: 1.0
  loss_neg_obj_weights: 1.0
  loss_class_weights: 1.0
  label_smoothing: 0.0
  big_grid_xy_extend: 0.05
  mid_grid_xy_extend: 0.05
  freeze_bn: false
  #freeze_blocks: 0
  force_relu: false
training_config {
  visualizer {
      enabled: False
      num_images: 3
  batch_size_per_gpu: 4
  num_epochs: 80
  enable_qat: false
  checkpoint_interval: 2
  learning_rate {
    soft_start_cosine_annealing_schedule {
      min_learning_rate: 1e-7
      max_learning_rate: 1e-4
      soft_start: 0.3
  regularizer {
    type: L1
    weight: 3e-5
  optimizer {
    adam {
      epsilon: 1e-7
      beta1: 0.9
      beta2: 0.999
      amsgrad: false
  pretrain_model_path: "/workspace/tao-experiments/yolo_v4_tiny/pretrained_cspdarknet_tiny/pretrained_object_detection_vcspdarknet_tiny/cspdarknet_tiny.hdf5"
eval_config {
  average_precision_mode: SAMPLE
  batch_size: 4
  matching_iou_threshold: 0.3
nms_config {
  confidence_threshold: 0.001
  clustering_iou_threshold: 0.3
  top_k: 1
augmentation_config {
  hue: 0.1
  saturation: 1.5
  exposure:1.5
  vertical_flip:0
  horizontal_flip: 0.5
  jitter: 0.3
  output_width: 1920
  output_height: 1088
  output_channel: 3
  randomize_input_shape_period: 10
  mosaic_prob: 0.5
  mosaic_min_ratio:0.2
dataset_config {
  data_sources: {
      label_directory_path: "/workspace/tao-experiments/data/train/labels"
      image_directory_path: "/workspace/tao-experiments/data/train/images"
  include_difficult_in_training: true
   target_class_mapping {
    key: "sedan"
    value: "sedan"
    key: "midtruck"
    value: "midtruck"
    key: "motorbike"
    value: "motorbike"
    key: "threewheeler"
    value: "threewheeler"
    key: "bicycle"
    value: "bicycle"
    key: "minibus"
    value: "minibus"
    key: "lighttruck"
    value: "lighttruck"
    key: "microbus"
    value: "microbus"
    key: "bigbus"
    value: "bigbus"
    key: "heavytruck"
    value: "heavytruck"
    key: "utility"
    value: "utility"
    key: "nmt"
    value: "nmt"
  validation_data_sources: {
      label_directory_path: "/workspace/tao-experiments/data/val/labels"
      image_directory_path: "/workspace/tao-experiments/data/val/images"
However, the training stuck with the following error:
INFO: Starting Training Loop.
Epoch 1/80
   470/186491 [..............................] - ETA: 214:20:58 - loss: 30052.7804INFO: 2 root error(s) found.
  (0) Invalid argument: Input to reshape is a tensor with 2108 values, but the requested shape has 2074
	 [[{{node bg_anchor_1/Reshape_1}}]]
	 [[loss_1/add_20/_3009]]
  (1) Invalid argument: Input to reshape is a tensor with 2108 values, but the requested shape has 2074
0 successful operations.
0 derived errors ignored.
  File "</usr/local/lib/python3.6/dist-packages/iva/yolo_v4/scripts/train.py>", line 3, in <module>
  File "<frozen iva.yolo_v4.scripts.train>", line 152, in <module>
  File "<frozen iva.common.utils>", line 707, in return_func
  File "<frozen iva.common.utils>", line 695, in return_func
  File "<frozen iva.yolo_v4.scripts.train>", line 148, in main
  File "<frozen iva.yolo_v4.scripts.train>", line 133, in main
  File "<frozen iva.yolo_v4.scripts.train>", line 83, in run_experiment
  File "<frozen iva.yolo_v4.models.yolov4_model>", line 731, in train
  File "<frozen iva.yolo_v4.utils.fit_generator>", line 222, in fit_generator
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/training.py", line 1217, in train_on_batch
    outputs = self.train_function(ins)
  File "/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py", line 2715, in __call__
    return self._call(inputs)
  File "/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py", line 2675, in _call
    fetched = self._callable_fn(*array_vals)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1472, in __call__
    run_metadata_ptr)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
2023-04-17 12:51:02,417 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I tried to set enable_auto_resize: true but it might not be supported. What else can I do?
This parameter is only available in detectnet_v2 network.
Please refer to DetectNet_v2 - NVIDIA Docs
