Hello, I am just trying to install tensor flow with this command pip3 install tensorflow and I am facing with an error like this “ERROR: Could not find a version that satisfies the requirement tensorflow (from versions: none)
ERROR: No matching distribution found for tensorflow”.
How to fix this error?. Thank you
TensorFlow doesn’t support the Jetson platform officially.
Please use our prebuilt instead.
I have followed the instructions but at the Installing TensorFLow step I found an error like this again
ERROR: Could not find a version that satisfies the requirement tensorflow-gpu==2.6.2+nv21.12 (from versions: none)
ERROR: No matching distribution found for tensorflow-gpu==2.6.2+nv21.12
Could you share which JetPack you use?
$ apt show nvidia-jetpack
I re-flash the system and install python 3.6.9 it work, previously i have installed python 3.8
Good to know you solve this now.
Thanks for the udpate.
