Hi… I am using matlab 14 . when I run a cuda file (.cu) , error comes like
Error using mex Creating library code.lib and object code.exp code.obj : error LNK2019: unresolved external symbol cublasDestroy_v2 referenced in function “void __cdecl gpu_blas_mmul(float const *,float const *,float *,unsigned __int64,unsigned __int64,unsigned __int64)” (?gpu_blas_mmul@@YAXPEBM0PEAM_K22@Z) code.obj : error LNK2019: unresolved external symbol cublasSgemm_v2 referenced in function “void __cdecl gpu_blas_mmul(float const *,float const *,float *,unsigned __int64,unsigned __int64,unsigned __int64)” (?gpu_blas_mmul@@YAXPEBM0PEAM_K22@Z) code.obj : error LNK2019: unresolved external symbol cublasCreate_v2 referenced in function “void __cdecl gpu_blas_mmul(float const *,float const *,float *,unsigned __int64,unsigned __int64,unsigned __int64)” (?gpu_blas_mmul@@YAXPEBM0PEAM_K22@Z) code.mexw64 : fatal error LNK1120: 3 unresolved externals
how can I get rid of it???
