Yunior
February 18, 2008, 8:08am
1
I tried to use CUBLAS library in *.cu file, but whenever I did it I faced a mistake :
:matrixMul.obj : error LNK2019: unresolved external symbol _cublasInit@0 referenced in function __Z7runTestiPPc1>…/…/bin/win32/Debug/matrixMul.exe : fatal error LNK1120: 1 unresolved externals
[1] Is there some way to overcome this problem ?
[2] Is it possible to use CUBLAS library in *.cu file ?
Y.
Y.
[snapback]328801[/snapback]
[1.] Probably you forgot to set the cublas library paths. Check in VS under project → project properties → configuration properties → link whether the links have been correctly set or not (compare with already existing sample projects).
[2.] Yes definitely.
