Having troubles with running tlt-train for resnet18_ssd. I’d be glad to hear any suggestions :)
Dataset is already resized to 480x272, converted to tfrecords with the following labels: person, windshield.
Full error message:
The shape of this layer does not match original model: conv1
Loading the model as a pruned model.
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/model_io.py", line 100, in load_model_as_pretrain
File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 1047, in set_weights
str(weights)[:50] + '...')
ValueError: You called `set_weights(weights)` on layer "conv1" with a weight list of length 2, but the layer was expecting 1 weights. Provided weights: [array([[[[-1.46843329e-01, -3.80116850e-02, 2.28...
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1607, in _create_c_op
c_op = c_api.TF_FinishOperation(op_desc)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Dimension 0 in both shapes must be equal, but are 1024 and 512. Shapes are [1024,176] and [512,176]. for 'Assign_557' (op: 'Assign') with input shapes: [1024,176], [512,176].
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 45, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/scripts/train.py", line 248, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/scripts/train.py", line 100, in run_experiment
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/model_io.py", line 117, in load_model_as_pretrain
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/model_io.py", line 51, in load_model
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/utils/model_io.py", line 30, in get_model_with_input
File "/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py", line 419, in load_model
model = _deserialize_model(f, custom_objects, compile)
File "/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py", line 287, in _deserialize_model
K.batch_set_value(weight_value_tuples)
File "/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py", line 2465, in batch_set_value
assign_op = x.assign(assign_placeholder)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/variables.py", line 2067, in assign
self._variable, value, use_locking=use_locking, name=name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/state_ops.py", line 227, in assign
validate_shape=validate_shape)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_state_ops.py", line 66, in assign
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1770, in __init__
control_input_ops)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1610, in _create_c_op
raise ValueError(str(e))
ValueError: Dimension 0 in both shapes must be equal, but are 1024 and 512. Shapes are [1024,176] and [512,176]. for 'Assign_557' (op: 'Assign') with input shapes: [1024,176], [512,176].
Train command:
tlt-train ssd -e specs.txt -r out/ -k $KEY -m resnet18.hdf5 --gpus 1
TLT-container: v2.0_py3
Train Specs:
random_seed: 42
ssd_config {
aspect_ratios_global: "[1.0, 2.0, 0.5, 3.0, 1.0/3.0]"
scales: "[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]"
two_boxes_for_ar1: true
clip_boxes: false
loss_loc_weight: 0.8
focal_loss_alpha: 0.25
focal_loss_gamma: 2.0
variances: "[0.1, 0.1, 0.2, 0.2]"
arch: "resnet"
nlayers: 18
freeze_bn: false
freeze_blocks: 0
training_config {
batch_size_per_gpu: 4
num_epochs: 100
enable_qat: false
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.15
annealing: 0.8
regularizer {
type: L1
weight: 3e-5
eval_config {
validation_period_during_training: 10
average_precision_mode: SAMPLE
batch_size: 4
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
preprocessing {
output_image_width: 480
output_image_height: 272
output_image_channel: 3
crop_right: 480
crop_bottom: 272
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 0.7
zoom_max: 1.8
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tlt-experiments/tlt-traffic/data/tfrecords/kitti_trainval/*"
image_directory_path: "/workspace/tlt-experiments/datasets/train"
image_extension: "jpg"
target_class_mapping {
key: "windshield"
value: "windshield"
key: "person"
value: "person"
validation_fold: 0
Thank you)
