Error while training with higher resolution images in yolo_v4 TLT-V3
Training yolov4 with TLT-V3 .
Image resoultion : 3840x2160
augmentation_config {
  hue: 0.1
  saturation: 1.5
  exposure:1.5
  vertical_flip:0
  horizontal_flip: 0.5
  jitter: 0.3
  output_width: 3840
  output_height: 2160
  randomize_input_shape_period: 0
  mosaic_prob: 0.5
  mosaic_min_ratio:0.2
Getting following error while running “tlt yolo_v4 train” command
Error :
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wh
eel.runfiles/ai_infra/iva/yolo_v4/builders/model_builder.py", line 49, in _load_pretrain_weights
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 1057, in set_weights
    'provided weight shape ' + str(w.shape))
ValueError: Layer weight shape (1, 1, 128, 64) not compatible with provided weight shape (1, 1, 64, 64)
During handling of the above exception, another exception occurred:
eel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py", line 209, in <module>
eel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py", line 205, in main
eel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py", line 83, in run_experiment
eel.runfiles/ai_infra/iva/yolo_v4/builders/model_builder.py", line 185, in build_data_and_model
eel.runfiles/ai_infra/iva/yolo_v4/builders/model_builder.py", line 52, in _load_pretrain_weights
ValueError: b2_conv2 has incorrect shape in pretrained model.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Co
mpile it manually.
  warnings.warn('No training configuration found in save file: '
Please share your full training spec and the full command line.
Please meet below requirement. https://docs.nvidia.com/metropolis/TLT/tlt-user-guide/text/open_model_architectures.html#yolov4
YOLOv4
  • Input size : C * W * H (where C = 1 or 3, W >= 128, H >= 128, W, H are multiples of 32)
  • Image format : JPG, JPEG, PNG
  • Label format : KITTI detection
train_spec.txt
random_seed: 42
yolov4_config {
  big_anchor_shape: "[(128.00, 340.00), (176.00, 428.00), (228.00, 596.00)]"
  mid_anchor_shape: "[ (35.66, 74.01), (65.83, 104.91), (100.00, 268.00)]"
  small_anchor_shape: "[(14.00, 24.48), (24.69, 42.35), (51.84, 49.37)]"
  box_matching_iou: 0.25
  arch: "cspdarknet"
  nlayers: 19
  arch_conv_blocks: 2
  loss_loc_weight: 0.8
  loss_neg_obj_weights: 100.0
  loss_class_weights: 0.5
  label_smoothing: 0.0
  big_grid_xy_extend: 0.05
  mid_grid_xy_extend: 0.1
  small_grid_xy_extend: 0.2
  freeze_bn: false
  #freeze_blocks: 0
  force_relu: false
training_config {
  batch_size_per_gpu: 4
  num_epochs: 400
  enable_qat: false
  checkpoint_interval: 5
  learning_rate {
    soft_start_cosine_annealing_schedule {
      min_learning_rate: 1e-3
      max_learning_rate: 1e-1
      soft_start: 0.3
  regularizer {
    type: L1
    weight: 3e-5
  optimizer {
    adam {
      epsilon: 1e-7
      beta1: 0.9
      beta2: 0.999
      amsgrad: false
  pretrain_model_path: "/workspace/tlt_pretrained_object_detection_vcspdarknet19/cspdarknet_19.hdf5"
eval_config {
  average_precision_mode: SAMPLE
  batch_size: 8
  matching_iou_threshold: 0.5
nms_config {
  confidence_threshold: 0.001
  clustering_iou_threshold: 0.5
  top_k: 200
  hue: 0.1
  saturation: 1.5
  exposure:1.5
  vertical_flip:0
  jitter: 0.3
  output_width: 3840
  output_height: 2160
  mosaic_prob: 0.5
dataset_config {
  data_sources: {
      label_directory_path: "/workspace/v1.2_split/train/labels"
      image_directory_path: "/workspace/v1.2_split/train/images"
  include_difficult_in_training: true
  target_class_mapping {
      key: "person"
      value: "person"
  validation_data_sources: {
      label_directory_path: "/workspace/v1.2_split/val/labels"
      image_directory_path: "/workspace/v1.2_split/val/images"
Command used for training :
tlt yolo_v4 train -e /workspace/specs/yolov4/yolo_v4_train_resnet18_kitti.txt -r /workspace/results -k xyz --gpus 4
Error :
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecat
ed. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-04-01 16:40:56,435 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_n
earest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
eel.runfiles/ai_infra/iva/yolo_v4/builders/model_builder.py", line 162, in build_data_and_model
eel.runfiles/ai_infra/iva/yolo_v4/builders/model_builder.py", line 98, in _build_model
eel.runfiles/ai_infra/iva/yolo_v4/architecture/yolo_arch.py", line 223, in YOLO
eel.runfiles/ai_infra/iva/yolo_v4/architecture/yolo_arch.py", line 95, in YOLO_FCN
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 431, in __call__
    self.build(unpack_singleton(input_shapes))
  File "/usr/local/lib/python3.6/dist-packages/keras/layers/merge.py", line 362, in build
    'Got inputs shapes: %s' % (input_shape))
ValueError: A `Concatenate` layer requires inputs with matching shapes except for the concat axis. Got inputs shapes: [(None, 256, 136, 240), (None, 512, 135,
 240)]
 240)]
 240)]
 240)]
 240)]
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[63215,1],3]
  Exit code:    1
  File "/usr/local/bin/yolo_v4", line 8, in <module>
    sys.exit(main())
eel.runfiles/ai_infra/iva/yolo_v4/entrypoint/yolo_v4.py", line 12, in main
eel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 296, in launch_job
AssertionError: Process run failed.
2021-04-01 16:40:58,873 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
output_height: 2160 is not multiples of 32. Please try others.
.Now getting “ResourceExhaustedError”. Tried by reducing following parameters
batch_size: 2
min_learning_rate: 5e-9
max_learning_rate: 5e-3
But still getting the error
What is the latest error log? Can you share the full log?
