Yolo_v4 getting stuck while training
• Hardware: T4
• Network Type: Yolo_v4
• TLT Version :
Configuration of the TLT Instance
dockers: [‘nvidia/tlt-streamanalytics’, ‘nvidia/tlt-pytorch’]
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
• Training spec file:
random_seed: 42
yolov4_config {
big_anchor_shape: “[(90.05, 188.05),(165.34, 131.00),(235.00, 278.53)]”
mid_anchor_shape: “[(76.00, 52.00),(46.50, 113.00),(118.00, 69.00)]”
small_anchor_shape: “[(28.00, 19.00),(54.02, 33.00),(29.17, 68.00)]”
box_matching_iou: 0.5
arch: “resnet”
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 24
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: “/workspace/tlt-experiments/yolo_v4/pretrained_resnet18/tlt_pretrained_object_detection_vresnet18/resnet_18.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 960
output_height: 544
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
label_directory_path: “/workspace/tlt-experiments/data/training/labels”
image_directory_path: “/workspace/tlt-experiments/data/training/images”
include_difficult_in_training: true
target_class_mapping {
key: “car”
value: “car”
key: “pedestrian”
value: “pedestrian”
key: “two_wheels”
value: “bike”
key: “person”
value: “pedestrian”
validation_data_sources: {
label_directory_path: “/workspace/tlt-experiments/data/val/label”
image_directory_path: “/workspace/tlt-experiments/data/val/image”
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
2021-07-29 16:48:15,927 [INFO] root: Registry: [‘nvcr.io’]
2021-07-29 16:48:16,273 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-07-29 16:48:24,935 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-07-29 16:48:24,935 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-07-29 16:48:25,075 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:55: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-07-29 16:48:25,076 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:55: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-07-29 16:48:25,587 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-07-29 16:48:25,590 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-07-29 16:48:25,614 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-07-29 16:48:26,246 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-07-29 16:48:26,508 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-07-29 16:48:29,049 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-07-29 16:48:30,004 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-07-29 16:48:30,005 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-07-29 16:48:30,842 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-07-29 16:48:31,858 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-07-29 16:48:31,862 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-07-29 16:48:32,650 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-07-29 16:48:32,826 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
Layer (type) Output Shape Param # Connected to
Input (InputLayer) (None, 3, 544, 960) 0
conv1 (Conv2D) (None, 64, 272, 480) 9408 Input[0][0]
bn_conv1 (BatchNormalization) (None, 64, 272, 480) 256 conv1[0][0]
activation_2 (Activation) (None, 64, 272, 480) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 136, 240) 36864 activation_2[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 136, 240) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 136, 240) 36864 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 136, 240) 4096 activation_2[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 136, 240) 256 block_1a_conv_shortcut[0][0]
add_9 (Add) (None, 64, 136, 240) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 136, 240) 0 add_9[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 136, 240) 36864 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 136, 240) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 136, 240) 36864 block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 136, 240) 4096 block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 136, 240) 256 block_1b_conv_shortcut[0][0]
add_10 (Add) (None, 64, 136, 240) 0 block_1b_bn_2[0][0]
block_1b_bn_shortcut[0][0]
block_1b_relu (Activation) (None, 64, 136, 240) 0 add_10[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 68, 120) 73728 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 68, 120) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 68, 120) 147456 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 68, 120) 8192 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 68, 120) 512 block_2a_conv_shortcut[0][0]
add_11 (Add) (None, 128, 68, 120) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 68, 120) 0 add_11[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 68, 120) 147456 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 68, 120) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 68, 120) 147456 block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 68, 120) 16384 block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 68, 120) 512 block_2b_conv_shortcut[0][0]
add_12 (Add) (None, 128, 68, 120) 0 block_2b_bn_2[0][0]
block_2b_bn_shortcut[0][0]
block_2b_relu (Activation) (None, 128, 68, 120) 0 add_12[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 34, 60) 294912 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 34, 60) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 34, 60) 589824 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 34, 60) 32768 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 34, 60) 1024 block_3a_conv_shortcut[0][0]
add_13 (Add) (None, 256, 34, 60) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 34, 60) 0 add_13[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 34, 60) 589824 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 34, 60) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 34, 60) 589824 block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 34, 60) 65536 block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 34, 60) 1024 block_3b_conv_shortcut[0][0]
add_14 (Add) (None, 256, 34, 60) 0 block_3b_bn_2[0][0]
block_3b_bn_shortcut[0][0]
block_3b_relu (Activation) (None, 256, 34, 60) 0 add_14[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 34, 60) 1179648 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 34, 60) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 34, 60) 2359296 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 34, 60) 131072 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 34, 60) 2048 block_4a_conv_shortcut[0][0]
add_15 (Add) (None, 512, 34, 60) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 34, 60) 0 add_15[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 34, 60) 2359296 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 34, 60) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 34, 60) 2359296 block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 34, 60) 262144 block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 34, 60) 2048 block_4b_conv_shortcut[0][0]
add_16 (Add) (None, 512, 34, 60) 0 block_4b_bn_2[0][0]
block_4b_bn_shortcut[0][0]
block_4b_relu (Activation) (None, 512, 34, 60) 0 add_16[0][0]
yolo_spp_pool_1 (MaxPooling2D) (None, 512, 34, 60) 0 block_4b_relu[0][0]
yolo_spp_pool_2 (MaxPooling2D) (None, 512, 34, 60) 0 block_4b_relu[0][0]
yolo_spp_pool_3 (MaxPooling2D) (None, 512, 34, 60) 0 block_4b_relu[0][0]
yolo_spp_concat (Concatenate) (None, 2048, 34, 60) 0 yolo_spp_pool_1[0][0]
yolo_spp_pool_2[0][0]
yolo_spp_pool_3[0][0]
block_4b_relu[0][0]
yolo_spp_conv (Conv2D) (None, 512, 34, 60) 1048576 yolo_spp_concat[0][0]
yolo_spp_conv_bn (BatchNormaliz (None, 512, 34, 60) 2048 yolo_spp_conv[0][0]
yolo_spp_conv_lrelu (LeakyReLU) (None, 512, 34, 60) 0 yolo_spp_conv_bn[0][0]
yolo_expand_conv1 (Conv2D) (None, 512, 17, 30) 2359296 yolo_spp_conv_lrelu[0][0]
yolo_expand_conv1_bn (BatchNorm (None, 512, 17, 30) 2048 yolo_expand_conv1[0][0]
yolo_expand_conv1_lrelu (LeakyR (None, 512, 17, 30) 0 yolo_expand_conv1_bn[0][0]
yolo_conv1_1 (Conv2D) (None, 256, 17, 30) 131072 yolo_expand_conv1_lrelu[0][0]
yolo_conv1_1_bn (BatchNormaliza (None, 256, 17, 30) 1024 yolo_conv1_1[0][0]
yolo_conv1_1_lrelu (LeakyReLU) (None, 256, 17, 30) 0 yolo_conv1_1_bn[0][0]
yolo_conv1_2 (Conv2D) (None, 512, 17, 30) 1179648 yolo_conv1_1_lrelu[0][0]
yolo_conv1_2_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_2[0][0]
yolo_conv1_2_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_2_bn[0][0]
yolo_conv1_3 (Conv2D) (None, 256, 17, 30) 131072 yolo_conv1_2_lrelu[0][0]
yolo_conv1_3_bn (BatchNormaliza (None, 256, 17, 30) 1024 yolo_conv1_3[0][0]
yolo_conv1_3_lrelu (LeakyReLU) (None, 256, 17, 30) 0 yolo_conv1_3_bn[0][0]
yolo_conv1_4 (Conv2D) (None, 512, 17, 30) 1179648 yolo_conv1_3_lrelu[0][0]
yolo_conv1_4_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_4[0][0]
yolo_conv1_4_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_4_bn[0][0]
yolo_conv1_5 (Conv2D) (None, 256, 17, 30) 131072 yolo_conv1_4_lrelu[0][0]
yolo_conv1_5_bn (BatchNormaliza (None, 256, 17, 30) 1024 yolo_conv1_5[0][0]
yolo_conv1_5_lrelu (LeakyReLU) (None, 256, 17, 30) 0 yolo_conv1_5_bn[0][0]
yolo_conv2 (Conv2D) (None, 128, 17, 30) 32768 yolo_conv1_5_lrelu[0][0]
yolo_conv2_bn (BatchNormalizati (None, 128, 17, 30) 512 yolo_conv2[0][0]
yolo_conv2_lrelu (LeakyReLU) (None, 128, 17, 30) 0 yolo_conv2_bn[0][0]
upsample0 (UpSampling2D) (None, 128, 34, 60) 0 yolo_conv2_lrelu[0][0]
concatenate_3 (Concatenate) (None, 384, 34, 60) 0 upsample0[0][0]
block_3b_relu[0][0]
yolo_conv3_1 (Conv2D) (None, 128, 34, 60) 49152 concatenate_3[0][0]
yolo_conv3_1_bn (BatchNormaliza (None, 128, 34, 60) 512 yolo_conv3_1[0][0]
yolo_conv3_1_lrelu (LeakyReLU) (None, 128, 34, 60) 0 yolo_conv3_1_bn[0][0]
yolo_conv3_2 (Conv2D) (None, 256, 34, 60) 294912 yolo_conv3_1_lrelu[0][0]
yolo_conv3_2_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_2[0][0]
yolo_conv3_2_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_2_bn[0][0]
yolo_conv3_3 (Conv2D) (None, 128, 34, 60) 32768 yolo_conv3_2_lrelu[0][0]
yolo_conv3_3_bn (BatchNormaliza (None, 128, 34, 60) 512 yolo_conv3_3[0][0]
yolo_conv3_3_lrelu (LeakyReLU) (None, 128, 34, 60) 0 yolo_conv3_3_bn[0][0]
yolo_conv3_4 (Conv2D) (None, 256, 34, 60) 294912 yolo_conv3_3_lrelu[0][0]
yolo_conv3_4_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_4[0][0]
yolo_conv3_4_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_4_bn[0][0]
yolo_conv3_5 (Conv2D) (None, 128, 34, 60) 32768 yolo_conv3_4_lrelu[0][0]
yolo_conv3_5_bn (BatchNormaliza (None, 128, 34, 60) 512 yolo_conv3_5[0][0]
yolo_conv3_5_lrelu (LeakyReLU) (None, 128, 34, 60) 0 yolo_conv3_5_bn[0][0]
yolo_conv4 (Conv2D) (None, 64, 34, 60) 8192 yolo_conv3_5_lrelu[0][0]
yolo_conv4_bn (BatchNormalizati (None, 64, 34, 60) 256 yolo_conv4[0][0]
yolo_conv4_lrelu (LeakyReLU) (None, 64, 34, 60) 0 yolo_conv4_bn[0][0]
upsample1 (UpSampling2D) (None, 64, 68, 120) 0 yolo_conv4_lrelu[0][0]
concatenate_4 (Concatenate) (None, 192, 68, 120) 0 upsample1[0][0]
block_2b_relu[0][0]
yolo_conv5_1 (Conv2D) (None, 64, 68, 120) 12288 concatenate_4[0][0]
yolo_conv5_1_bn (BatchNormaliza (None, 64, 68, 120) 256 yolo_conv5_1[0][0]
yolo_conv5_1_lrelu (LeakyReLU) (None, 64, 68, 120) 0 yolo_conv5_1_bn[0][0]
yolo_conv5_2 (Conv2D) (None, 128, 68, 120) 73728 yolo_conv5_1_lrelu[0][0]
yolo_conv5_2_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_2[0][0]
yolo_conv5_2_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_2_bn[0][0]
yolo_conv5_3 (Conv2D) (None, 64, 68, 120) 8192 yolo_conv5_2_lrelu[0][0]
yolo_conv5_3_bn (BatchNormaliza (None, 64, 68, 120) 256 yolo_conv5_3[0][0]
yolo_conv5_3_lrelu (LeakyReLU) (None, 64, 68, 120) 0 yolo_conv5_3_bn[0][0]
yolo_conv5_4 (Conv2D) (None, 128, 68, 120) 73728 yolo_conv5_3_lrelu[0][0]
yolo_conv5_4_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_4[0][0]
yolo_conv5_4_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_4_bn[0][0]
yolo_conv5_5 (Conv2D) (None, 64, 68, 120) 8192 yolo_conv5_4_lrelu[0][0]
yolo_conv5_5_bn (BatchNormaliza (None, 64, 68, 120) 256 yolo_conv5_5[0][0]
yolo_conv5_5_lrelu (LeakyReLU) (None, 64, 68, 120) 0 yolo_conv5_5_bn[0][0]
yolo_conv1_6 (Conv2D) (None, 512, 17, 30) 1179648 yolo_conv1_5_lrelu[0][0]
yolo_conv3_6 (Conv2D) (None, 256, 34, 60) 294912 yolo_conv3_5_lrelu[0][0]
yolo_conv5_6 (Conv2D) (None, 128, 68, 120) 73728 yolo_conv5_5_lrelu[0][0]
yolo_conv1_6_bn (BatchNormaliza (None, 512, 17, 30) 2048 yolo_conv1_6[0][0]
yolo_conv3_6_bn (BatchNormaliza (None, 256, 34, 60) 1024 yolo_conv3_6[0][0]
yolo_conv5_6_bn (BatchNormaliza (None, 128, 68, 120) 512 yolo_conv5_6[0][0]
yolo_conv1_6_lrelu (LeakyReLU) (None, 512, 17, 30) 0 yolo_conv1_6_bn[0][0]
yolo_conv3_6_lrelu (LeakyReLU) (None, 256, 34, 60) 0 yolo_conv3_6_bn[0][0]
yolo_conv5_6_lrelu (LeakyReLU) (None, 128, 68, 120) 0 yolo_conv5_6_bn[0][0]
conv_big_object (Conv2D) (None, 24, 17, 30) 12312 yolo_conv1_6_lrelu[0][0]
conv_mid_object (Conv2D) (None, 24, 34, 60) 6168 yolo_conv3_6_lrelu[0][0]
conv_sm_object (Conv2D) (None, 24, 68, 120) 3096 yolo_conv5_6_lrelu[0][0]
bg_permute (Permute) (None, 17, 30, 24) 0 conv_big_object[0][0]
md_permute (Permute) (None, 34, 60, 24) 0 conv_mid_object[0][0]
sm_permute (Permute) (None, 68, 120, 24) 0 conv_sm_object[0][0]
bg_reshape (Reshape) (None, 1530, 8) 0 bg_permute[0][0]
md_reshape (Reshape) (None, 6120, 8) 0 md_permute[0][0]
sm_reshape (Reshape) (None, 24480, 8) 0 sm_permute[0][0]
bg_anchor (YOLOAnchorBox) (None, 1530, 6) 0 conv_big_object[0][0]
bg_bbox_processor (BBoxPostProc (None, 1530, 8) 0 bg_reshape[0][0]
md_anchor (YOLOAnchorBox) (None, 6120, 6) 0 conv_mid_object[0][0]
md_bbox_processor (BBoxPostProc (None, 6120, 8) 0 md_reshape[0][0]
sm_anchor (YOLOAnchorBox) (None, 24480, 6) 0 conv_sm_object[0][0]
sm_bbox_processor (BBoxPostProc (None, 24480, 8) 0 sm_reshape[0][0]
encoded_bg (Concatenate) (None, 1530, 14) 0 bg_anchor[0][0]
bg_bbox_processor[0][0]
encoded_md (Concatenate) (None, 6120, 14) 0 md_anchor[0][0]
md_bbox_processor[0][0]
encoded_sm (Concatenate) (None, 24480, 14) 0 sm_anchor[0][0]
sm_bbox_processor[0][0]
encoded_detections (Concatenate (None, 32130, 14) 0 encoded_bg[0][0]
encoded_md[0][0]
encoded_sm[0][0]
Total params: 20,215,304
Trainable params: 20,193,160
Non-trainable params: 22,144
2021-07-29 16:49:06,324 [INFO] main: Number of images in the training dataset: 10235
Epoch 1/80
Whenever I try to train Yolo_v4, it just gets stuck at that point, no errors are reported.
Running nvidia-smi yields:
| NVIDIA-SMI 465.19.01 Driver Version: 465.19.01 CUDA Version: 11.3 |
| | | MIG M. |
| 0 NVIDIA Tesla T4 On | 00000000:AF:00.0 Off | Off |
| N/A 69C P0 29W / 70W | 15706MiB / 16127MiB | 0% Default |
| | | N/A |
Can you set batch_size_per_gpu to a lower value and retry?
I’ve tried, it sometimes run and sometimes doesn’t and I can’t recognize any pattern as to when it gets stuck. I’m guessing it’s got something to do with my particular server rather than TLT itself. Thank you
